Question about Canon MultiPASS F60 All-In-One InkJet Printer
Color When I print anything the color comes out green.
    Genius:
  • 2,035 Answers
1. Load letter-size plain paper in the multi-purpose tray.
2. Press <Menu>.
3. Use [<] or [>] to select [MAINTENANCE].
4. Press <Set> twice..
Please let me know whats colors do you get from the print ...
Posted on Dec 03, 2008
Whenever I try to print anything w/color, the yellow in the inkjet cartridge does not come out--instead of the color green it comes out blue or instead of the color red it comes out pink. I put in a brand...
Could be the communication between the printer and the computer...(operating system or driver) or, it could be the ribbon cable that connects to the print head. or, it could be the connection where the cartridge connects to the printer, may be dirty. Get some long Q-tips and some alcohol and get in there and clean it. (don't clean up any necessary white grease that keeps it lubricated though)
Jun 12, 2010 | HP Deskjet D4360 InkJet Printer
It prints blue instead of green when i print. anything that should be green turns out totally blue. any help? i've reset and calibrated twice.
have you tried replacing the color cartrige if so then the printer may be broken and uses the wrong colors its uncommon but does happen
Dec 19, 2009 | HP LaserJet 3600n Printer
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer does not come out of the Manual color setting
When printing tell printer to use color space sRGB.
let printer determine color.
see if that works.
Mar 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
COLOR PRINTING CANNON PIXMA 3000
yes you need a saringe with some nail varnish remover init then remove cartriges then inject nail varnish in the printer jets you can tell if there blocked as it will hard to squirt in but keep going till it easy to do then you will no it clear then just put a blank sheet of paper in it and run it after you have cleaned the exses up of course
Feb 23, 2008 | Office Equipment & Supplies
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Colour management
Check the printer driver. I had the same problems - b+w with green tints, colors not rigt.  I'm using a Mac, but noticed that under the Color Matching options of the printer driver the default is "vendor matching" - switch to "ColorSync" and see if that works for you. Did for me.....
Good luck
SteveP in Italy
Oct 18, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
Canon MultiPASS F60 All-In-One InkJet Printer Logo
old marine
old marine
