Question about AMD ASUS A7N8X-VM/400 Motherboard
PC with poss ASUS A7N8X - VM motherboard problem
When PC switched on screen flashes up 'No Signal' for a few seconds then goes off.
M/c does not post/ boot -up . An IT colleague of mine says after inspecting it that the motherboard 'has gone' .
Any ideas, fixes or solutions grateful.
Thks
  • gavin570 Dec 02, 2008
    the motherboard detail (based on the spec)
    ASUS A7N8X-VM nVIDIA GeForce4 (sma) with 10/100 Ethernet LAN
    PC is a MESH Matrix M2800+XL purchased in Feb 04
    Processor is AMD Athlon XP (TM) 2800+ with Quantispeed Technology
    Memory : 512 Mb PC2700 DDR Memory 333 MHz
    Hard Drives 120Gb Ultra Fast with Buffer (7200rpm)
    Hope this helps , will not see your reply until tomorrow .
    Thks for any help.
    Gavin@gavinmacleod.co.uk
  • gavin570 Dec 05, 2008
    I have a fix in place thanks to Compdoctor20.
    Scholar:
  • 172 Answers
Can you give me motherboard & pc infoinfo, the symptoms certainly suggest mobo failure
Posted on Dec 02, 2008
  • Chris Fell
    Chris Fell Dec 02, 2008
    Hi Gavin, reply sent to your email address. Motherboard has blown options to replace on email to your address above.
    Chris
  • Chris Fell
    Chris Fell Dec 05, 2008
    Look forward to meeting you on Saturday 6th for the replacement and upgrade of your computer.
Need sm bus controller and ethernet driver for a7n8x-vm motherboard
Go to the Asus site:
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Choose :
"Motherboard"
"Socket A (465)"
"A7N8X-VM"
in the dropdowns.
Enter your OS
Choose the "IDE" driver, that is actually an "all-in-one" chipset driver that should get you taken care of.
Feb 15, 2011 | ASUS A7N8X-VM Motherboard
I have an asus a7n8x motherboard and I switched all the guts from my case and put into a new one. Now I cannot get my video card to read at all, and I had no problems with the video card prior. WHAT DO I...
Switch off the pc and open the pc cover.
Remove CMOS batteryand press on of switch for 40 seconds.
Start your pc and pres F2/F10/ Dell for setup bios .
Disable on board graphics.
or set graphics priority
Follow bellow links for basic knowledge.
Phoenix BIOS setup and help
or
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
save and exit or pres F10(funtion key).
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | ASUS A7N8X-VM Motherboard
Problem with ASUS P5GD1 mobo
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
Feb 05, 2010 | ASUS P5GD1-VM Motherboard
I NEED DRIVERS FOR A7N8X-VM/400
All the drivers for your Asus A7N8X-VM/400 can be found on Asus Global link. Click the link below to open the site;
http://www.asus.com/product.aspx?P_ID=OYMrFEShYfp6m1dg
Have more problems post your question here.
Thank you for using Fixya!
Mike
Jun 24, 2009 | AMD ASUS A7N8X-VM/400 Motherboard
Asus a7n8x-vm nic driver
hello..Good Day...this is the way to find your need drivers>>>(http://www.nodevice.com/driver/A7N8X/get31422.html)>>>Good Luck
Jun 10, 2009 | ASUS P5PE-VM Motherboard
Installing extra memory causes freezing + closing down of pc
Check these specs for your board.it will support 2gb but only if its pc2700.anything greater will not boot or become unstable quickly.here are your specs.also i am enclosing an ASUS link for any and all manuals etc. for this board.asus a7n8x-vm motherboard
Specifications www.microsoft.com/Genuine"] --> CPU Socket A for AMD Athlon XP
Thoroughbred/ Barton Core Support Chipset NVIDIA nForce2 IGP
NVIDIA nForce2 MCP Front Side Bus 400/333/266 MHz Memory -Dual Channel Memory Architecture
-Supports up to 2GB of 2700/PC2100 DDR memory
-2 DIMM sockets Expansion Slots AGP8X (1.5V only)
3 x PCI VGA -Integrated GeForce4 MX GPU
-Integrated TV encoder
-NVIDA nVIEW dual-display architecture
-Support DVI (AGP-NV-DVI) and TV out (AV/S) cards Storage/RAID 2 x UltraDMA 133/100 Audio Realtek ALC650 6-channel CODEC
S/PDIF in / out interface LAN Integrated 10/100 Mbps LAN controller + Realtek PHY USB Integrated 6 USB2.0 ports Special Features Power Loss Restart
Support S/PDIF in / out interface
ASUS MyLogo2
ASUS C.O.P. (CPU Overheating Protection)
ASUS EZ Flash Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x VGA
1 x Audio I/O
1 x RJ45
4 x USB 2.0/1.1 BIOS 4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, ASUS MyLogo2 Industrial Standard PCI 2.2, USB 2.0 Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME, Chassis Intrusion Support Disc Drivers
ASUS PC Probe
Trend Micro™ PC-cillin 2002 anti-virus software (OEM version)
ASUS LiveUpdate Utility Accessories User's manual
UltraDMA cable
FDD cable
I/O shield Form Factor microATX Form Factor, 9.6"x 9.6"(24.5cm x 24.5cm)RICHARDM69
Dec 15, 2008 | ASUS A7N8X-VM Motherboard
Computer will not boot up
no most popularly its because u have filled up the ram slots some pc need to have the driveres installed to take the ram try taking all the ram out apart from one stick in slot one the turn the monitor/tv on and then the pc this should work if i dosent then the pc is booting in too high or too low a resilution normaly too low try using a old moniter jst to set the pc up but try the ram first normally works
Dec 02, 2008 | AMD ASUS A7N8X-VM/400 Motherboard
AMD ASUS A7N8X-VM/400 Motherboard Logo
309 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
