Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Fridge was "hot" on the inside when I opened
I opened the fridge this morning and it was hot; the light element was very warm to the touch. A stick of butter melted to liquid. I unplugged and called a local repair service and they didn't know what the problem was. They plugged in the unit again and told me to check in a few hours to see if it happened again. What to do??
  • 89 Answers
Sounds like compressor out or relays on the compressor out. Is freezer side ok? If so you may have a defrost problem... http://www.houstongofarappliancerepair.com/Refrigerator.html
Posted on Dec 02, 2008
How can I tell if my water line tank heating element is broken? Should it get warm to the touch?
no it should not. If fridge fan is working water should not freeze.
check for fan motor operation.
Apr 03, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
My Subzero bar frig feels quite hot around the edge that touches the rubber and it is making the rubber warm as well. Everything inside is cold, and it is making ice as usual. I think I sense a smell of...
as with alot of refrig units the rubger strip has a warming coil that keeps the door from sticking they keep an even warm temp so as opening and closing the door easy there could be a burn spot in the strip and causing the strip tp be warmewr than it should be almost hot should call a fridge expert after you convince your other half there is a prob normally most fridges have a plan magnetic strip to seal the door
Aug 22, 2009 | Refrigerators
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Haier hsp03wna not working
The click you heard is the thermal overload. This snaps open when the compressor is too hot.
Unplug the unit for 24 hours and don't move it.
Then plug it in and see if it comes back on temp.
Jun 02, 2009 | Haier HSP03WNA Compact Refrigerator
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge/freezer warm, no fan, light's on
you can remove back cover feel the compressor, is it hot?? perhaps it overheate.
Feb 24, 2008 | Refrigerators
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
200 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
