Question about HP Office Equipment & Supplies
My printer says it is out of ink when it has a new cartridge
  • bass2bass Dec 08, 2008
    It was of no help as I had already tried those solutions before contacting you.
    I called technical support, and they replaced the printer.
    Sergeant:
    Champion:
  • 200 Answers
Hi
Clean the head and check whether u have placed the cartridge properly...and then restart the system and printer and then try it..
thank you
Posted on Dec 02, 2008
    Problem Solver:
  • 14 Answers
Some mis-connects with cartridge clean it
  • dhavalsanjay Dec 09, 2008
    clean the cartridge senser and then check the cartridge whether it is short or not....if yes then pls contect your system administator for the printer
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
Tip
How to replace the ink cartridges on a Dell All-In-One 948 Inkjet Printer 1....
1. Turn the printer on.
2. Lift the printer unit.
3. The ink cartridge carrier moves and will stops at the loading point unless the printer is busy.
4. Press down on the ink cartridge lever to raise each ink cartridge lid.
5. Remove the old ink cartridges from the printer.
6. If you are installing new ink cartridges, then remove the sticker and transparent tape from the back and bottom of each ink cartridge.
Note: If you are wanting to print photos you will want to install a photo cartridge along with the color cartridge. Also if you are switching between the photo and black cartridge but they still have ink in them be sure to store then in an air tight container so they do not dry out.
7. Insert the new ink cartridges. Making sure that the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier.
8. Snap each lid closed
on Apr 01, 2010 | Dell 948 All-In-One InkJet Printer
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
How to remove ink from printer
Ink Cartridge Maintenance
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  2. Open the front cover.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
How to instal a new printer ink cartridge
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Replaced ink in printer with generic ink cartridges and error message 1203 came up.
A person might notice that buying new, name brand, ink cartridge for printer rapidly becomes quite an expenditure. Nonetheless, there are quite a lot of different methods to find the equal quality standard for a alot lower price. Your primary options are: name brand (OEM) ink cartridge for printer, matching generic ink printer cartridges or remanufactured ink printer cartridges.
When you are purchasing a replacement photo printer cartridge, consumers do have choices. It’s frequently assumed that shoppers are required to buy the expensive, name brand, cartridge for laser printer from the manufacturer, or the service contract will become void. Their belief merely is not correct. By law, the use of compatible replacement inkjet printer cartridges does not render null and void the printer makers guarantee. In truth, you can choose to get less pricey compatible cartridge for laser printer, or remanufactured cartridges, often with a realized savings of between 40% and 75%. All chief ink laser printer cartridge brands have matching versions, including IBM, and Xerox.
Name Brand Inkjet Cartridge for Laser Printer
Nearly all major makers of laser printers also create the replacement inkjet printer cartridges that are best matched for their particular laser printers. This option is ordinarily the most expensive, and in a lot of situations it is the lone choice available if you happen to get a new laser printer whose producer implanted computer chips in the ink printer cartridge. The point of this chip may possibly be to regulate the color ink flow, limit the cartridges use, or to standardize the cartridge in alignment. Nevertheless, if you pick out a similar, or remanufactured, cartridge for laser printer, it might not be able to interconnect with the laser printer and may harm the laser copier or cause it to quit working.
Comparable Generic Inkjet Cartridge for Laser Printer
When thinking about purchasing an ink printer cartridge for your laser printer, the key aspect you must to bear in mind is the price. Buying a brand new ink laser printer cartridge will be based upon how much you are prepared to give. You can buy a new brand name cartridge for printer, or you might purchase a new compatible (generic) ink printer cartridge. Both types of ink printer cartridges might provide you with the same quantity, quality and performance you insist on from your printer. The major difference is in cost: a brand name ink printer cartridge might easily cost nearly twice the price of a compatible cartridge for printer.
Compatible (generic) inkjet laser printer cartridges are made to meet OEM (Original Equipment Manufacturer) specs. These makers usually set very lofty standards of dependability and quality and also provide high quality results, regularly exceeding the quality specifications established by the OEM. These cartridge for printer are produced with new parts and are a lower priced option to costly name brand ink printer cartridges.
Buyers might also be surprised to see that the generic comparable cartridge will publish the same amount of, or more, pages than the original OEM cartridge. Largely, this is since certain original OEM ink laser printer cartridges are not filled all the way up. In this situation, a compatible ink cartridge for printer could give you twice the advantage: it reduces your price per cartridge and cost per page by printing additional pages
Dec 27, 2009 | Dell 926 All-In-One InkJet Printer
Hi there
Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
21 people viewed this question
Seeker5211
Seeker5211
