Question about NorStar M7310 Corded Phone
Display - wont work properly
My phone will not display "you have messages" when there are unread/unretrieved messages in the voice mailbox ..... the display reads the date and time.
I have tryed unplugging the phone and leaving
  • peteb47 Jan 05, 2009
    Hi. I have checked it and every day there is at lease one new message. I erase them after I've listened to them .... but with each new message, there is no message on the screen?
Do the following:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
4. Press the softkey under "MBOX"
5. Press the softkey under "CHNG"
6. Enter your extention number
7. Press the softkey under "NEXT" untill it shows Msg waiting: if it is chosen to show Msg waiting: N, Select the softkey under "CHNG" to make it Msg waiting: Y.
8. Press the softkey under "OK"
9. Press Rls
Posted on Sep 14, 2009
Have you checked voicemail? Do you have any new messages?
Posted on Jan 02, 2009
  • Anonymous Jan 05, 2009
    Try powering the voicemail down first, by unpluggin it. After about 5 minutes it should be back up, if so, do the same to the phone system. See if that does anything...
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I retrieve voice mail messages from my uniden dect 6.0?
LED on the handset flashes and appears in the handset display whenever you have messages waiting in your
Feb 13, 2013 | Uniden DECT 6.0 Cordless Telephone...
I work at a small company and recently they have set me up a voice mailbox on a norstar m7310 Phone and Star Talk mini. The mailbox works fine but the store manager is unable to configure my phone to...
In the mailbox setup, there's a prompt called EXT .. make sure your extension number is there. There's another prompt called MSG WAIT (or something like that) which needs to be set to YES or Y. The person that setup the mailbox should be able to get to these settings.
May 13, 2011 | NorStar Meridian M7310 Phone
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
http://www.gen-i.co.nz/Solutions/Mobility/Device_Documents/Nokia%20E71/Setting%20up%20Voicemail%20on%20the%20Nokia%20E71.pdf
Apr 15, 2011 | Nokia E71 Smartphone
My message light will not turn red so I am not aware that I have a message. If I push the "message" button, it is busy
You are missing a lot of information, but here goes. Your message light is unlikely broken in a new phone. Have someone ring your extension and press "4". Now look at your phone and press MESSAGE. The display tells you who left the message and you get 2 options on your soft keys to call or erase the message.
Now, here's the part you left out. What is leaving the message? It could be coming from CO based voice mail, a TVA system, or a SVM card. If it's a TVA voice mail system, it has to be programmed with your mailbox and extension (usually the same). A message left in the General Delivery Mailbox doesn't light anything unless it's programmed to do something, and a message left in your box usually works if it's properly set up to begin with. We try to set up our TDA's to eliminate GDM messages, so that means that Call Forward lights must be lit at every extension that needs voice mail and there's always a choice to direct callers to extension 101 or some other mailbox but the GDM. If it's CO based, you bought the wrong system, and an SVM card has a set of instructions to assign extensions to slots.
Most likely you'll find the missing information in the Programming Manual of the voice messaging system.
Carl
Jan 11, 2011 | Panasonic KXDT333 Phone
We have a KX-TA624 phone system connected to a TVS50 voice processing system. I have one user who has a KX-T7730 phone and his message button wont light when a voice message is left for him. I know the...
The user may have brushed onto the 62x commands to change or turn off message notification. From the subcriber's mailbox, choose option 621 and make sure it's enabled, then 622 and make sure you're using option 2. (continuous). If neither of these work, have the owner log into mailbox 999 and make sure that the owner's extension of the broken extension matches the extension. That's option 611 mailbox number and follow the prompts. The extension is the mailbox.
Carl
Aug 05, 2010 | Panasonic KX-T7730 Corded Phone
HOW TO RETRIEVE VOICE MESSAGES? DOES THE PHONE DISPLAY YOU HAVE A VOICE MESSAGE? IF NOT, THEN WHAT IS THE FEATURE CODE TO ENTER AND OBTAIN MSGS.
The display on a Nortel set will say "message for you" if there's a message in your mailbox. To access your voicemail you can press your open voicemail key if its programmed or press feature 981.If you wish to retrieve your messages remotely, call your office, when the autoattendant answers the call press ** followed by your extension number, your password then # (ex. **2231234#).
Jul 09, 2010 | NorStar M7208 Corded Phone
Norstar M7208 telephone
This could be because you have several mailboxes/extensions set up. We've had the same problem in our office.
As a result, from the phone that reads "Messages for you" you can find out which mailbox is attached to the phone.
1. Press "Feature"
The display will read: "Set: ???"
The numbers shown in place of the question mark will be the numbers to the mailbox attached to the phone.
2. Press "Feature"
Enter 981 for voice mail access
The display will read "Login: "
Enter the numbers from the previous action, and if you don't know the password, attempt to use the default passwords of 0000 or 1234.
This worked at our office. I hope it works for you.
If not? We find the site http://nortstarsupport.com VERY helpful.
If you don't know the password, but have access to the system administrator login, you can reset the password for the set you are trying to retrieve messages.
Good luck
Jul 14, 2008 | NorStar Lands Phones
NorStar M7310 Corded Phone Logo
195 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
