Question about Bush DVD142RC 14 in. TV/DVD Combo
SOUND SYSTEM I HAVE NAIKO TV MODEL N2850W,IT HAS A PHILIPS VERSION. I TRIED TO CHANGE SOUND SYSTEM FROM I TO BG BUT IT HAS NO ANY CHANGES,ALMOST STAY STANDARD I WHILE I WANT TO CHANGE IT TO BG. HAVE YOU GOT THE WAYS OR CODES FOR OPENING SYSTEM BG?
Sony bravia
please first go to setup & then go to antenna manual setting then you can change the tv system at BG
Feb 12, 2016 | Sony Televison & Video
How can change sony wega tv sound system from bg to dk/
Refer its user manual for details. You can select the system by entering its menu [sound]. Electro help
Sep 23, 2014 | Sony Wega Multi-System 21" Tv...
How do i change the system of bush btv180tsil tv/vhs pal I to pal BG
Just go to its menu option first. There you can change the sound system to PAL B/G, NTSC, andso on. Select the system to PAL B/G first. Then make an auto tune function, All the channels sorted by the TV will automatically tuned and stored in memory with PAL B/G only.
google.com/+GopakumarGopalan
Nov 26, 2013 | Televison & Video
I need to change my kdl-40ex405 sound format to bg how do i do this
Hello
Your TV has no 'BG' sound system with it. It is made for use in US only and have NTSC system with it. It cannot be changed to BG where as BG sound comes with PAL system TVs only. OK
Jun 24, 2011 | Sony Bravia KDL-40S51009 40 in. TV
My samsung tv wont stay on..model number hl5677wx/xxa version plo1 serial 31ey500119v
Check the lamp first. If you haven't tried that yet, that's your first step! Buy only an OEM Philips from an AUTHORIZED dealer.
Feb 03, 2010 | Samsung DLP HL-P5663W 56" TV
JVC TV
you should have a button on your remote for sound system may be 'BG' or 'SYS' or any other press it to change sound system to "BG". sound will be ok.
Nov 01, 2008 | JVC AV32F476 32" TV
Faulty Audiosonic Tv
Hi, I have an audiosonic 51 cm LCD tv. the problem is i can't change the sound system from BG to M.It also ask me for input password when i go to function. Please help!
Jul 01, 2008 | Televison & Video
Disney c1320ptvd-car change sound system BG to DK
c1320ptvd
LANGUAGE SETUP MENU
select preffered language
AUDIO LANG
mini disks must contain the preffered language otherwise they play the preselected language.
user manual found in greek language.
http://www.winlink.gr/data/files/DISNEY%20DVD%20C1320PTVD-CARS.pdf
Dec 12, 2007 | Disney DTD1363-CAR 13" TV/DVD
Sound Level Changes Constantly
Make sure digital sound control is not set to optimal
Make sure incredible surround is off
Press optimal sound mix until it says "OSM Off"
Double-check the speaker connections
May 07, 2007 | Philips FWC399 CD Shelf System
Bush DVD142RC 14 in. TV/DVD Combo Logo
19 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
