Question about HP Photosmart C3180 All-In-One InkJet Printer
Hi, How to refill the cartridge for Canon MP220 printer.I dont know where to make the hole.This is my first time refilling the cartridge.Thank you. Sir , How to refil the tricolour ink cartridge for the HP Photosmart C3188, printer,
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
Best to get it done right, take your ink cartridges to Costco (most USA/Canada/Mexico stores) or any Frys Electronics store....the photo center/service center folks are fully trained on refilling of over 240 different types of the latest ink cartridges...and it's inexpensive!!
Posted on Jul 25, 2013
  • 796 Answers
You shud use a syringe to inject the ink from the container to the ink tank..
Posted on Dec 02, 2008
    Genius:
  • 1,605 Answers
There is small breathing hole on top of the cartridge. inser the the refill needle there.
    Problem Solver:
  • 14 Answers
Remove the top cover of cartridge and just use your common scence you will refill it
How to refill ink cartridges
dont refill ink cartridges it may damage your printer and your printing quality.buy original..
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi, I am using Canon 1454MP 3 - in - one printer, can you tell me if refilling my cartridges will work fine (which costs Rs 100 - 250) , r I have to buy a new cartridge everytime? Please help
All canon cartridges can be refilled but you need to know the following:
  1. Use Dye Based inks, not water based
  2. Do not refill the cartridge if it is completely empty, it may not work
  3. Keep in mind the ink levels can not be reset after a refill, so you will have to put up with a empty cartridge warning.
It is much more cost effective to refill than to purchase a new cartridge. We have successfully refilled these types of cartridges over 10 times each.
These links below will also provide useful information regarding refilling.
  1. http://www.fixya.com/support/r8894299-re_filling_cartridges_facts_fiction
  2. http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps, If so please rate this answer below Thank You for supporting the FixYa Community Regards GM
Apr 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Instructions on how to refill the the ink cartridge for a Canon mp730 .
You can easily to refill it only one time.If itself open cartridge and hole top of the cartridge push refill ink and close tide and tide.First time clean cartridge OEM software by printer default.
May 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Error code U163 on cannon pixma mp220 printer
Those cartridges don't refill unless you have a way to reset the internal chip. Check online for refillable cartridges or a chip resetter. For priming you go into printer properties and choose maintenance and head cleaning, or choose cleaning from the front panel.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
My canon mp220 printer wont work after putting in
Try to press and hold "resume" button for 5 seconds.If this not help the color cartridge may defective.
Oct 09, 2009 | Canon Office Equipment & Supplies
I have refilled the ink cartridges on my Canon Pixma MP220 printer but how do i reset the printer to show the ink level is replaced as it is still showing low ink-thanks
try this
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again. dont forget to rate thank you
Nov 30, 2008 | Office Equipment & Supplies
Refilled ink cartridges not recognizby printer.
I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
