Question about HP Photosmart C7180 All-In-One InkJet Printer
HP C7280 - Just Stopped printing on only One of my computers
I have the HPC7280 printer. I've had it installed on my home computer and work laptop for a couple of months now. Connected through wireless. Now all of sudden the printer will not work on my laptop. Everything works on my home pc. All of the scanning functions work on my laptop, just no printing. I went through the Windows troubleshooter and nothing. I deleted the printer and uninstalled the HP program. I reinstalled it and I have the same problem. Can anyone help?
This is a HP C7280 All in One printer (listed on the front of the printer)
  • dbradica Dec 02, 2008
    The picture shows a black printer however, mine is white. Here is a link to photo.
    http://www.photographyblog.com/images/pr...
  • dbradica Jan 30, 2009
    The solution has been found. After much troubleshooting with HP and EDS, un-installing the program, cleaning up files, downloading a new version etc... The solution was to un-install the file, deleted all program folders and clear out the Registry (through "run" command of "regedit") of all drivers and reference to the HP printer. For that matter we removed all Lexmark and other Network printers just to be sure. I was told that the other printers could be added later.
Had a similar problem. Try downloading the printer drivers again from HP website.
Posted on Dec 10, 2008
How to restore the "scan to email" function on my HPC7280 printer screen?
This is usually caused from your printer not being able to find your computer. When you get into the scan menu, and go to scan to computer, does the name of your computer show up there? If not, that is the problem. You'll need to re-establish connectivity between the computer and your printer.
There are a few technical things to do, but the very easiest is to simply uninstall the software from your computer and then download the latest code from HP, located here.
Once you have it installed and it has found your computer, when you scan, a screen will appear on your computer showing all the functions. Using that list, make sure the option you want is loaded and then update the printer using the "Update" button.
Mar 11, 2010 | HP Photosmart C7280 Printer
HP C7280 doesn't print 2-side from my computer
have you use duplex unit?
you have to change your driver option both side print
Thanks
Oct 27, 2009 | HP Photosmart C7280 Printer
HP c7280 Stuck in print que...
Please click here and follow the instructions to clear the print queue manually.
Oct 07, 2009 | HP Photosmart C7280 Printer
How can I connect my wireless laptop to print wirelessly?
run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
Jun 21, 2009 | HP Photosmart C7280 Printer
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
Wireless problem
First we need to check whether there is a communication between the computer and the all-in-one. Once print the network configuration page from the all-in-one and collect the IP address of the all-in-one and pste it on the address bar of the internet explorer and press enter, this should open the printers information page, if it is opened then there is a communication between the computer and then all-in-one. Now disable the firewall and antivirus and then try to install the drivers. If there is no communication then try to assign the IP address manually to the printer depending upon the computers IP address.
Apr 27, 2008 | HP Photosmart C7280 Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
119 people viewed this question
Ben Johnson
