Question about Nikon COOLPIX L18 Digital Camera
Can I use a polaroid brand memory card in a coolpix L18
I have a new L18, and want to know if I can put a used memory card in it and use it. Would it be advisable to also get an ac adapter for it? And can the set up be changed each time you change batteries oruse the adapter? I am a totallly new to photography, and am afraid of ruining the camera. Thank you!
  • 4,806 Answers
Most camera cards are interchangable, just check the specs and see what the camera supports, the camera card won't break it wether its old or new, make sure the card isn't in the "lock" possition thought
Happy Snapping
kind regards and don't forget to rate us
Posted on Dec 02, 2008
    Sergeant:
    Champion:
  • 200 Answers
Hi
U can use adapter...
Read the user manual in that itself they will tell clearly....
thank you
Olympus SP 800uz not deleting pix from built in memory !?!
Flash memory takes time and power to erase memory. Did you use new battery or AC adapter? And how long did it take to erase all the images?
Feb 08, 2012 | Cameras
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
Memory card filled and I took more pictures. Seemed to put those on the internal memory. What happened too or how can I recover the memory card pictures?
Probably one of two solutions.
First, the memory card should have all the pictures intact. If you are using the camera to review, you may need to just keep going back until the memory card photos show.
Another possibility is that the internal memory supersedes viewing the card memories. You may have to run a USB cable to your computer, download the internal memory photos, and then you can possibly see (on the camera) the memory card photos. It might be a good idea to download those photos to your computer too, if the computer has a memory card slot. Otherwise you will have to go through them and download via the USB again. Once you know the photos are saved, you can either change cards with a new one , or clear the old card and start again.
Good Luck
Mar 04, 2011 | Nikon COOLPIX L18 Digital Camera
I found one in my desk at work. It's missing a memory card thus no one is using it. What kind does it take? Can it be by any brand?
It can take a SD memory card or SDHC memory card, recommended brands: SanDisk, Toshiba and Panasonic from 128 MB to 4 GB capacities.
The manual and other information for the Coolpix L18 is available from Nikon: http://www.nikonusa.com/Nikon-Products/Product-Archive/Digital-Camera/25596/COOLPIX-L18.html . The list of memory cards is on page 91.
I hope this helps.
Jan 07, 2011 | Nikon COOLPIX L18 Digital Camera
Have picture on my L18. Hook to a USB port.. Have
Are you using the Nikon software? It should be able to see the picture. Also, the camera has both a memory card and internal memory. If the picture is on the internal memory and a card is inserted, the picture will not show up. Remove the card.
May 30, 2010 | Nikon COOLPIX L18 Digital Camera
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Memory card won't stay in
Make sure you push in firmly untill it clicks . Make sure its an SD card Too.
Jul 05, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon transfer is not showing that my camera is connected
There is an alternate way of downloading images from the memory card from the camera.
Get a USB memory card reader, remove the memory card from the camera, insert it into the card reader, then plug the card reader into the USB port of your computer. You will now see card reader as an external memory device, open the folder and copy your photos onto your hard drive.
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Camera does not recognize memory card
It appears the SD card the retailer sold is not compatible with the camera. Put in a different memory card and camera works fine.
Dec 28, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
