Question about Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 TV won't turn on
Was turning off by itself intermittently and now has turned off and I can't turn it on at all. Do I need a new main board or a new power supply board?
  • 1 more comment
  • jsroda Dec 03, 2008
    I don't understand your question? Are you inlet power supply to the TV?
    What do you mean?
    If you are saying do I have the TV plugged in the answer is yes, and yes I have tryed different outlets.
    What do I check on the power board?
  • 75 Answers
Try giving the power supply to other place and check it if not turning on then their might be a short circuit inside tv
Posted on Dec 03, 2008
    President:
  • 2,267 Answers
In this case it might be hard to pin point the failure. I would suggest to measure the voltages from the power supply first to isolate the failure. In about 95% of the time if the TV is not powering up properly or it has to be unplug to work, the failure is in the power supply.
Click here to find a power supply for your TV. I can repair them for about $30.00 less.
Let me know if you require further assistance.
  • 10,594 Answers
Do you see any flashing light code on TV?
as its LCD TV so possibilities are power board, main board or back light inverter boards.
    Genius:
  • 1,550 Answers
Are you inlet power supply to the tv ?
If you are not getting try from other socket .
If you are getting power supply through inlet socket then you need to check the power board .
  • Sanyo Master
  • 19,396 Answers
You do not know what the fault is until teh TV get tested.
Start unplugging the power cord for ten minutes or so, ans see if this clears the error message.
  • Ginko
    Ginko Dec 03, 2008
    If the TV started shutting down by itself , this is likely to be a problem with the power supply board.
    To know what the problem is the on board component must be tested.
    The best solution is always calling a technician, so that you do not risk damaging your TV.
    If you have experience in fixing electronics, get the service manual and follow the troubleshooting diagrams to test the TV and find the faults.
    An initial test will be checking the internal board to see if some of the power capacitor on the power board look bulged or chipped, the TV should be left unplugged for few hours before taking it apart safely.
    You can buy service manual here
    http://www.manualsparadise.com/AboutOurS...">Sanyo Service Manuals
    Get parts here:
    Partstore
Tv wont display hdmi connection when pressing input on remote or changing channels on the tv itself
Try a hot swap. Turn off the television and the connected equipment. Remove the hdmi cable for a minute or two. Plug the cable back in in another hdmi input if possible. Turn the television on. Turn the connected equipment on. You may need another hdmi cable. At most you will need to replace the hdmi board in the television.
Oct 28, 2010 | Sanyo DP32746 32 in. LCD Television
TV turns off by itself(not sleep mode) usually turn back on sometimes unplug & try again in 5 min.s
This problems is the cause by the power supply board is dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP32746 32 in. LCD Television
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
I have a Sanyo LCD-32CA9S. Turns off after 10 minutes
Tru using your remote to access the factory reset mode to default. It might be hard to find, but it should be listed in your tools or settings options somewhere. Also, you can unplug the set for 5 minutes and then plug it in again. This resets the computer in several models. It's like a hard reboot.
Jul 31, 2009 | Sanyo DP32746 32 in. LCD Television
TV shutting off
its the problem of ic numbers 438 or ic nuber 453 getting overheated on the main board .this ic needs to be checked and repaired.
Mar 06, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo 32" TV has no Picture sound fine.Model DP32746
Dec 03, 2008 | Sanyo DP32746 32 in. LCD Television
Shadow on the screen
our 32 inches flate p tv is not turning on an off no power
please help
Feb 09, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
146 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
