Whenever I see this problem I look for reasons why the dryer stopped heating. You might think the heating element is the priority thing to check and you would be right. But their are other things to look for besides the element. I inspect the dryer inside and out for signs of lint buildup and vent blockage. If I see a lot of lint I know it might very well be a safety limit has popped. Most dryers have 2 limits mounted next to the heater element on the heater housing.A lager one is rated @250f and a smaller one is rated @300f. If that smaller limit is tripped then you will have no heat,however, the dryer will still run. If the filter housing and blower area really get a lint buildup then a melting fuse rated @350f will kill the dryer so that the thing won't catch fire. I have manuals and repair photos for most American models HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
[p]
