Question about Euro-Pro S3325 Handheld Steam Vacuum
No Steam after heating up
Machine changes from heating to steam ready but no steam is coming out.
  • snglrose Dec 18, 2008
    I have the same problem - ready light comes on, and there is steam inside the canister, but when I press the steam on switch on the handle, nothing happens
You're screwed. Buy a new one..just not THIS brand. It's cheaper. I can see it is made to last 1 to 1 1/2 years and then FORCE you to buy a new one.
Posted on Aug 10, 2009
Sounds like the switch on the handle or the steam release solenoid on the steam chamber is faulty ,use a volt meter/tester to see if you have current to the solenoid when you turn on the switch.
Posted on Dec 20, 2008
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
It heats water inside the machine, but won't steam
contact Shark . they will know better and faster than we could find it .
Oct 20, 2015 | Shark S3501 Steam Pocket Floor Mop With 5...
I have a vax steam mop it was working perfectly
possibly not heating if you have water and no heat it could be a problem with the heating cycle that allows the steam to work .
You need a technician to have a closer look at it. It could be something small like a wire off or it could be major like an element problem. Take it in & ask for a quote on getting your machine working again.
Sep 01, 2014 | Vacuums
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
Jan 26, 2014 | Oreck VersaVac Bagless Vacuum / Steam Mop
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
My steam cleaner seems like its heating up but the steam is not coming out of the hose!
It is likely that you have a thermoswitch problem. Mine seems to have the same problem. You plug it in and it says ready, but steam does not come out. Here's a picture of the thermoswitch. If you can find a replacement part, let me know I need one too.
Jan 23, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
When I turn it on the ready light automatically comes on but does not heat. No steam. What could the problem be?
Did u find the answer to this problem? My beloved shark is doing the exact same thing.
By tmoffett99 on Sep 23, 2010
Sep 23, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
I have the Euro Pro Steam Caddy #S3325H. I have had it for years and have never used it. Now I have a ceramic bathroom and dirty grout. There are no instructions in the box, and I can't get the steam to...
dont steem this grout,,,it will only fall out or you could crack a tile,,,wipe on some strong bleach/loo cleaner and scrub it with a stiff brush its a lot safer than steeming it
Aug 21, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Machine will not produce steam. Machine will heat up but not enough to produce steam. Help ...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;a
Jul 31, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: shark steam mop has water, but there is no steam....
I tried running vinegar through as you would a coffee pot to get rid of hard water scales. This did not work. Then I noticed that the light behind the shark decal on the front of the machine was going off and on. And sure enough as I moved the cord around the light would come off and on. Looking closer I could see the the heat had melted thru some of the cord.I bought mine at Target before xmas last year, throwing away the sales slip after several months so I guess there is nothing I can do about it.
May 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro S3325 Handheld Steam Vacuum Logo
217 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
