Question about E-Machines T2792 PC Desktop
E-Machines T2792 PC Desktop is not booting
Hey all, I wonder if somebody else has run into this: The PC is an E-Machines T2792 and belongs to my mom. She walked in on it one day and found it powered on, but not booted. No output to video and the lights for the CD and HD simply blink non-stop. No discernable code or pattern to the blinking and the PC won't even get to CMOS. Upon closer inspection, I noticed that the power button seemed to be jammed. I was able to depress the button and get it to boot once, but upon reboot was back at square 1 (blinking lights). After taking the side panel off, I also noticed that while the power supply comes up and running, the CPU fan does not. I'm quite sure that the power button was damaged by one of the grand-kids (ages 2 and 4) while mom was out of the room. Could this have also caused some damage to the mother-board or processor? Any trouble shooting suggestions are welcome.
  • 1 more comment
  • Gregg LaFlamme Jan 31, 2007
    Sandrew,
    Thank you for the suggestion, unfortunately for me it didn't work, but then again, on this machine, I didn't find exactly what you described either. (probably becuse this machine is a proprietary piece of JUNK!) ;-)
    After doing a google on JBAT1, I figured that you were instructing me to clear the BIOS. When I took a look at the MB I could not find a JBAT1 circut, however, I did find circuts with jumpers labled j1 through j4. Also I found a sticker on the inside of the cabinet showing that these circuts were for bios settings. J4 was the one listed to clear bios, so moved it from the 1-2 setting to the 2-3 setting for 20 seconds. After moving back to the 1-2, I then tried to boot. No go, same symptoms, could not even getinto bios.
    Any other suggestions? I appreciate your time.
  • Gregg LaFlamme Feb 01, 2007
    Thanks, I'll give it a try. I am worried that the MB is dead, but if that's the case, there isn't much else I'll be able to do except try and find a replacement or rob the peripherals and start a new build.
  • ptheerow Nov 29, 2007
    i am having the same problem (wahlumssp) power supply turns on and the
    cpu fan doesnt and the power led is yellow...changed out the power
    supply but its somthing else either the mb is dead or cpu..but im not sure...were you able to fix your mother's comp..
Sandrew, Thank you for the suggestion, unfortunately for me it didn't work, but then again I didn't find exactly what you described either. There was no JBAT1 on the MB, there were, however, circuts with jumpers labled j1 through j4. I figure that the difference in the labling may be due to the fact that this is a proprietary brand. After doing a google on
Posted on Jan 31, 2007
    President:
  • 2,961 Answers
This could be a corrupted bios, look on the motherboard for the 'JBAT1' terminal and put the plastic jumper cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Start the pc hopefully and press F2 or DEL to enter the bios and set the time and date in standard bios settings and look for the auto detect drives and select it. press ESC and and save settings and it will re boot and go into windows if the softwaere was not corrupted when it was turned off at the button.
Posted on Jan 30, 2007
  • andrew pester
    andrew pester Jan 31, 2007
    it's unusual that you cannot get into the bios, so try taking the cmos battery out(disc shaped watch type battery) for 15 minutes or so and try again.
I WANT TO RESTORE MY FACTORY SETTINGS BUT I DON'T HAVE THE CD
I researched your question for you. The disks are avaliable but there is a cost to replace them. Click on this link or copy and paste the link into your web browser so it takes you there, here is the link.
http://recovery-disks.com/emachines/emachines-desktop/emachines-desktop-t-series-t2792.html
I hope this helps you out, if it does please click Yes on the web page you are reading this email on. Thank you.
Apr 05, 2011 | E-Machines T2792 PC Desktop
I have an e-machine T2792. It boots up fine then runs for 10 to 20 min. then shuts down. Could this be my cpu going bad? Thank You Scott
CPU, the motherboard and the rest of the chips in it is subject to wear and tear. This is in addition to the high temperature it is operating with. The sudden shut down is cause by a failure of one component (usually the Processor) who's burned out.
Sep 12, 2010 | E-Machines eMachines Desktop PC
I need help restoring my emachine t2792 to factore default settings
Go to start menu -> Click on all programs -> click on Emachine ->click on Emachine recovery management -> Click on restore on the bar across the top ->click on restore to system factory default. This will take some time and reset your Computer to factory default. Note:- This will erase all your data also so create backup if anything important is there before you reset to default. If this process doesn't work for you or you dont find the option then Use the disk bundled with PC to restore/reinstall Windows.
May 24, 2010 | E-Machines T2792 PC Desktop
Where is the battery on the T2792 desktop?
Looks like it stands on it's edge on the bottom of the mainboard below the last PCI slot.
May 06, 2010 | E-Machines T2792 PC Desktop
How do i do a recovery without a the disk
depends on what are you trying to recover?
if u want to recover the data then u can connect the hdd to any other external device and do the recovery.
if u want to recover the os then u can boot and recover from the system partation if u have one.
Jan 10, 2010 | E-Machines T2792 PC Desktop
E-Machines T2792 (Windoes XP Home) Shuts down occasionally. I just want to reformat my hard drive and start fresh, but do not have the OS Reinstallation disks and e-Machines doesn't have them any more....
Check your program list and see if there is an emachines backup or restore CD creation application. Most recent computers did not come with disks. Instead, the user needs t create their own. If you've never created a set, you might be in luck. Directions should be on their website.
Aug 05, 2009 | E-Machines T2792 PC Desktop
Need driver-- restored and PC no longer recognizes
heres the website to the network download for your comp.=www.emachine.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T2792
Jun 29, 2009 | Computers & Internet
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Shut down
Check to make sure you're not going into Stand-By mode. Click on the Start Menu....Shut Down and make sure you're not clicking on Standby.
Feb 23, 2008 | E-Machines eMachines Desktop PC
E-Machines T2792 PC Desktop Logo
187 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
