Hoover Floormate H3000 Upright Wet/Dry Vacuum
Problem for Hoover Floormate H3000 Upright Wet/Dry Vacuum
Does not put water on floor
By spicerjr on Dec 02, 2008
I am being told that because I put vinegar in the water that I have ruined the machine. Is this possible!! I use the hoover cleaner then ever other time the vinegar and water.
Same Problem
Jan 09, 2009
-   I have the same problem---H3000 will not pump the cleaning sloution on to the floor when the triger button is pushed! -   chazsc
Jan 08, 2009
-   Everything works, but it will not put solution on the floor!-   kshkut
Jan 03, 2009
-   Suction works, brushes work, but the machine doesn't spit the water/solution, rendering it completely useless. Could there be a clog somewhere I don't see?-   ckrotter
Solution #1
posted on Dec 03, 2008
Not Rated)
tresilla
Rank: Guru
Rating: 87%, 1615 votes
vinagar should not hurt the machine
Was this helpful?
Yes
No
Popular Solutions for Hoover Floormate H3000 Upright
Questions and Unsolved Problems for Hoover Floormate H3000 Upright
Do you recommend Hoover Floormate H3000 Upright Wet/Dry Vacuum?
Answer
Answer
Floormate Wet/Dry Water pours from the clean water reservoir when the machine is tipped back in the... (More)
Answer
I need to clean out the blocked hose on my wet/dry floor mate, please help
Answer
Hoover floormate Gets little to no suction when set to both Dry and Wet Pick up.
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in Van Nuys, CA
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
