P50hdm hello,do you know how to trouble shoot the y and z boards on the vizio p50hdm?
  • smarkle Dec 08, 2008
    first of all thanks so much for replying. The TV has no picture at all or sound. all my boards are made by LG. thanks again for your help.
    Scholar:
  • 72 Answers
Ok first i need to know is the TV showing anything at all or just a blank screen ? And if you know what the Y or Z board is who is the manufactured of the plasma panel is ?
Posted on Dec 06, 2008
  • James Peters
    James Peters Dec 13, 2008
    In plasma tvs your if its the same as other manufactures the board on the left and right are the Y and X boards they control the display.
    If you dont have sound also then its not your Y or X board. its probably your main board ssb ( usually the main board that the av/hdmi/coaxial all plug into.
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on Vizio P50HDM
Check you voltages before just swapping out boards. Although a YSUS is common for no picture, so is your upper and lower Y Buffer boards or the panel itself. Check youe -VSC voltage. Does it look like it is being loaded down? If so then your YSUS is not the problem. You can run the set with just the upper or lower Y Buffer boards untill the load is gone. That will let you know wich board to replace.
Jun 20, 2012 | Vizio Televison & Video
Anyone have a service manual for a Vizio P50HDTV20A?
Hello
I've with me the service manual you need; is for Vizio P50HDM; but I can't send it to you by this site as you know. If you send your email address to me by FixYa comment box, I'll send a copy of it to you by return mail. OK.
Jun 09, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio p50hdm red flashing pixels
Try to adjust the Vs voltage on the power supply by lower it a little bit or increase it a little bit. It will help to decrease the red pixel flashing.
Apr 24, 2009 | V, Inc. Vizio P50HD Plasma Television
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
407 people viewed this question
Top Televison & Video Experts
