Question about Coronado P.S.T. CaK Telescope
PST CaK, can't see any light coming through.
Yes, the lens cover is off and I can see the light in the finder but I can't see any form of light coming through the lens. Tried on several clear, sunny days and nothing yet. Please advise.
  • 4 Answers
I don't know quite what you mean by the "finder" as it doesn't come with a finder scope but it sounds as if it wasn't pointed directly at the sun.
Posted on Jan 12, 2009
Tip
Conversion of MBOX file in Outlook PST
Conduct the change of email things from MBOX to PST documents by making full usage of Kernel for MBOX to PST Conversion tool. The utility is not difficult to work and in the meantime is sagaciously customized that further empowers its client to precise and perfect transformation of MBOX documents into MS Outlook PST or MSG document form. By utilizing this product, it is all that much conceivable to change over just those email things containing connections. What else makes this product not quite the same as other is its seeing gimmick that shows review of included MBOX documents before sparing and further allows sparing changed over email information according to envelope chain of command. Separated from this, the instrument has got brilliant office to effectively safeguard all the email metadata data (To, Cc, Bcc, From, Sent & Received Date, Attachments), Read and Unread status of messages while directing MBOX to PST transformation. Likewise, the product gives complete backing to Unicode character change. Additionally, the product is totally good with all the forms of MS Outlook: MS Outlook 2000, 2002, 2003, 2007, 2010 and 2013. Underpinned OS are Windows XP, Windows Vista, Windows 7 and Windows 8, Windows 8.1, Windows Server 2000/2003/208/2008 R2 stages. Separated from this, the product is effortlessly accessible in free trial form. With the assistance of trial adaptation of Kernel for MBOX to PST programming, any individual can assess its abilities before obtaining full form. The free trial form precisely changes over MBOX records to PST or MSG organize however at the same time put certain limitations. It limits the client from sparing just 25 things for every MBOX record. Thusly, with a specific end goal to spare whole changed over email information, it gets crucial for client to buy the full form of Kernel for MBOX to PST programming. For more points of the software, click here MBOX to PST Converter
on Nov 21, 2014 | Computers & Internet
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Owners Manual
I've heard that Humminbird will be happy to send you a manual, just fill out the contact form supplied here:
http://www.humminbird.com/support/faq.aspx?ask=yes
Apr 29, 2010 | Bottom Line Fishin' Buddy 1101 GPS...
Lens cycles in & out upon start up and view finder blurry.
Here's the procedure for a manual reset...remove the card and battery...press all the buttons...insert the card and then the battery...turn on the camera.
Sep 10, 2009 | Olympus FE-340 Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Have lint and small specs on inside part of viewfinder, how do you clean this
It may not be the view finder. My guess is that there's some dust on the lens. It will look like the dust is inside the view finder but its actually not. Do these "spec" appear on pictures too? If yes then you will need to clean your lens/get it cleaned.
Let me know if you need more help,
Sai.
Aug 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
I have a Coronado PST and can't seem to see anything through it??? I can get the sunlight in the finder window, but don't have any glimpse of an image in the lens. It is almost if there is something...
HI lyuen: its possible the finder scope/window is not aligned properly , or these type of scope need very careful focusing. otherwise it will be difficult to see the sun.
hope this helps.
Dec 02, 2008 | Coronado P.S.T. CaK Telescope
My lcd and view finder are unable to show subject
The problem you are having is called a "stuck iris" Inside the lens are two thin plastic sheets that slide over one another that limit the amount of light that comes into the lens. In some Sony camcorders, the motor or "actuator" that drives the iris, or moves the two sheets which are the iris opened and closed. The actuators sometimes leak oil onto the plastic sheets causing them to stick, so the light coming into the lens is stuck at one level. Some technicians will recommend lens replacement (expensive) but many times the iris assembly can be removed from the lens and cleaned. Try to find a service shop that will clean the iris rather than replacing the lens.
Nov 11, 2008 | Sony Handycam CCD-TRV98 Camcorder
I have a Samsung VP-D20 The camcorder switches on ok, all the information appears in the view finder or on the LCD but there is no recording image on the screen or in the view finder, the recording light...
Yes I have solved the problem with this camcorder. I had a scrap unit which had a liguid spillage. Thanks to your help I stripped both units down and changed the lens assembly complete with the electronics, the camcorder now works fine.
I am waiting for help with a samsung D 363.
Regards James.
Mar 30, 2008 | Samsung Cameras
Coronado P.S.T. CaK Telescope Logo
193 people viewed this question
Top Coronado Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Coronado Optic Expert? Answer questions, earn points and help others
