Question about Acer Aspire 5500 5570-2609 Laptop
Intermittent internet connectivity
Have an Acer Aspire laptop with 64 bit Windows Vista connected wirelessly to Verizon router. Up until Nov 26, it has worked fine - no problems. Did a Microsoft upgrade Nov 26 and it went into a do loop on the install for several hours (overnight). I reloaded all the software from the harddrive (I beleive including wireless adapter software). Now I get intermittent internet connection, it keeps intercepting a neighbor's unsecured signal and not accepting my router's signal (it is security enabled. I keep trying to reset it to my router's signal and it goes back to my neighbor's signal which weak to poor. I have contacted Verizon but have not heard from them yet. Since thanksgiving day this has been going on.
My wifi is extremely slow on this exact Acer laptop model. I am using Windows 8 64-bit. Updated everything. Wifi is still unusually slow. Please help. (Acer Aspire Q5WPH/T6)
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.Com before and after following these steps.
Sep 08, 2013 | Acer Aspire Computers & Internet
Does acer aspire 4315 wire less net supports in win7 ? ?
As of the moment there is no driver support for the Acer Aspire 4315. If you have already installed Windows 7 and you can connect to a cable internet through your Ethernet Port, you can try downloading and install Driver Genius Professional which can assist you in getting the compatible driver. Since this software can detect even unknown devices.
Aug 20, 2010 | Acer Aspire 4315 Notebook
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Cant connect to the internet even tho it says you are connected
One solution, (especially if you are using built-in wireless networks) is to 'reinstall Vista'...and set the
permissions (i.e. leave everything wide open until you know you are connected).
Solved my problem by doing the 64 bit upgrade.
ww
Oct 04, 2009 | Acer Aspire One PC Notebook
I have a acer aspire 5315. I bought a D Link dir 615 wireless internet router. The problem I am having is that I can connect to the router, but I cannot connect to the internet. What is the problem?
Hi the router has not picked up your IP address.follow this Turn off your wireless router and internet connection and your laptop aswell for 30secs .Then first turn on your internet (if seperate from the router) if not switch on the wireless router/internet hub and wait untill the lights stop flashing then switch on your laptop and that should work.
Dec 15, 2008 | Acer Aspire 5100 Notebook
Wireless connection problems
Download driver Acer Aspire 5100 for Atheros Wireless adapter ar5007ag
Aug 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Jun 09, 2008 | Acer Aspire 4315 Notebook
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
