Question about Smeg 24 in. DWI612 Built-in Dishwasher
Smeg Built -in dishwasher
My integrated dishwasher has trouble starting and then fails to do a full cycle once it has started. It is built-in so you start the timer (push button) before you shut the door. It then starts the pumping noises, sometimes these noises are a bit laboured and sound more like teenage groans. Water flows in and drains and the heating element works, it just doesn't do the important stuff like wash my dishes. My hands are not meant for washing dishes, please help.
  • 641 Answers
SOURCE: smeg dishwasher problem
Water supply to the dishwasher is done through an electromagnet valve,loocated at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
Posted on Jul 20, 2007
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
  • 8 Answers
Check to make sure there r no kinks’ in the drain line or that it is not clogged it sounds like the sensor is tripping because there is too much strain on the pump just like a breaker.
Posted on Nov 08, 2007
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
  • 258 Answers
SOURCE: Smeg dishwasher tripping out fuseboard
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Posted on Jan 18, 2009
Testimonial: "Sorry it has taken so long to get back to you......forgot the log in details and sorted it in the meantime. Thanks for replying though. :)"
  • 109 Answers
SOURCE: SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Posted on Jun 16, 2009
0 characters
1 Points
How do i start the cycle
Short of getting the manual, you will have to figure out by trial and error each button- most importantly the start. Then one by one chart the location and function of each button and when satisfied, mark them on the d/w with indelible ink.
Dec 13, 2013 | Smeg DWI614 Built-in Dishwasher
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Smeg Dishwasher SA 620 X-Soap dispenser won't open!
Sounds like the solenoid in the dispenser has failed. Youll need to replace it
Please leave feedback
Feb 12, 2009 | Smeg CSU2001 Built-in Dishwasher
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Dishwasher Whirpool not finishing a cycle.
control board issue needs to be looked at by whirlpool tech in your area, still under warranty
Apr 10, 2008 | Smeg PLA8743XU Full Console Dishwasher...
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Nov 18, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Smeg 24 in. DWI612 Built-in Dishwasher Logo
23 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Level 1 Expert
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
