Question about Bachmann Toys
Can't bachmann reversing trolley to run on extended layout
We are running the trolley on an extended layout of approximately 50 board feet. There are four wires coming out of the controller. Blue, white, green, and yellow. how do I wire up the track to get the trolley to run on code 100 track like it does on the prewired snap track?
  • 1,498 Answers
Hi Papajj,
HO scale has only the tracks to convey power, therefore ultimately only two wires will be needed.
The original setup had the Power Pack separate from the variable speed controller. There was also the 'Bump Stop' reversing capability function of the snaptrack.
I assume your new layout is a continuous loop with the auto reverse no longer needed.
So to go directly from the controller to your new setup you need to identify which of the wires are responding to the the controller.
You will need a voltmeter set to DC. A digital would be preferable since we are unsure of polarity.
  • Set the controller to midrange
  • Pick a color for one lead then check the other three with the other lead.
  • When the meter registers, adjust the speed controller. When you turn it up, does the meter register an increase? (keep in mind the increase may be negative since the poles can be reversed. This is ok).
  • These are the two wires you need to attach to your new track layout.
Happy Holidays and Thanks for using FixYa
Posted on Dec 02, 2008
  • 1,605 Answers
This is guess on my part. But I think it will work.
First take a look underneath the trolley, there should have 4 contacts.
Now you need a voltmeter, put the control in forward, measure the track in pair, 1&2, 3&4 1$3, 2&4, without the trolley, and write down the reading.
Now put the control in reverse, and do the same measurement.
You should a good idea what is hot when the trolley in forward and what is hot in reverse. Wire the track accordingly.
You should be in business.
  • Frank
    Frank Dec 02, 2008
    The other method is the apply votage to the trolley contact in pair and find out which 2 pair is for forward and which is for reverse. wire the track accodingly.
How many feet in 8mm
no feet in 8mm
roughly 8mm is 1/3 of an inch or 3/8 "
Oct 23, 2017 | Video Cameras
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
Jan 08, 2016 | Bachmann Ho Bachmann Thomas and Friends...
Netgear65 n750 not effective 40 ft. away
If the router has "N" value it should run a good distance away, even to the neighbors home. If "G" 30 Feet to 50 feet max.
40 Feet is difficult if passing through thick walls or steel buildings. If it is not an "N" router, then you need that or an Extender system. See TigerDirect for hardware replaements.
Apr 15, 2014 | NetGear WGR614 Wireless Router
Bachmann Emily
check all track connectors(squeeze lose ones with a needle nosed pliers..check wire from transformer to the track..and during assembly, the track gets any dust on it, the wheels wont make proper contact for the engine to run..) as for the locomotive.. sometimes you can clean the motor brush comutator with a simple pencils' erasure by rotating the motor armature by hand(small as it is) to clean the pickups on will better help to transferr the electric into the motor..sometimes on these track layouts, you need fine grit sandpaper to run across the top of the rails as the manufaturer puts a protective coating on these.. it wont carry power to your can also use the backside of a butterknife drug around the layout a few times with the electric off.. it helps you feel any rough spots on the track/layout..
Mar 08, 2014 | Bachmann Thomas Tank Emily's HO Train
Driver Wheels are not aligned properly. Will not run in reverse without de-railing.
Best best is to send it back to the parts & service department, they will either repair it or replace it. It should have a lifetime warrantyif you are the original owne If not under warranty, I believe the charge is $35.00 for repair/replacement.But check with parts & service.
link is to Bachmann Parts & Service.
Apr 10, 2012 | Bachmann HO Scale Classic Collector Series...
Replaced the mini belt without incident, actually pretty easy to do. Reinstalled the unit onto the screw and hung in place. Reinserted the wires by color and plugged in the power. The rack and connected...
Start over by removing the belt.
Release the door from the trolley.
Then slide the door/trolly latch mechanism toward the motor assy half way,
Reinstall the belt but not the door to the trolley.
Ativate the remote and where the door stops, assuming it is closing , is the lower/closed limit.
Remove the belt, again.
Then side the door latch mechanism near the end of the trolley.
Reinstall the belt and activate the remote.
It should be close enough to fine tune using the limit switches.
Jul 26, 2011 | liftmaster Chamberlain 20B17 Mini Drive...
I just bought a Bachmann - Spectrum® Village Street Car Christmas Train Set - On30, for my window display and for some reason it only flips into reverse at the end with the car barn, but not at...
Make sure that the last track before the bumper is marked to be at the end of the trck - it will be marked on the bottom of the track and there will not be electrical connectors at one end of the track.
Nov 25, 2010 | Bachmann On30 Christmas Village Street Car...
Toys Logo
306 people viewed this question
Top Bachmann Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Bachmann Toy Expert? Answer questions, earn points and help others
