Question about Intuit Quicken Deluxe 99 for Windows (quicken99)
I have set up a budget for my expenses but now I would like to go back and adjust the original figure I have entered. How do I adjust that figure? I have Quicken Deluxe 2002 version.
  • 407 Answers
Edit the budget in transactions.
Posted on May 22, 2009
My business is 6 months old I need to know how to enter the history of the company I have been keeping the books by hand
I would recommend these steps.
1. Go back to the bank statement you received from your bank back to the point where you want to start your company history
2. Set up accounts that fit your type of business or pick from one of the template business accounts they provide. Typically this is automatically done when you first set up quickbooks
3. Open the Quickbooks check register and start entering all the expenses and deposits you made for the past 6 months exactly like you would enter them in a check book register. It's easy but can be time consuming.
That's all there is to Quickbooks. It's a great software program that will show you monthly P&L and I recommend you take the time to set up company budgets so you can know exactly what it cost to run your business. Budgets are under <Company> then <Planning and Budgets> depending on the version you have.
Hope this helps.
Sep 29, 2013 | Intuit Computers & Internet
Can you adjust the timing chain on a 97 ford mustang 3.8 V6 to get more horsepower?
No. There are no adjustments that accomplish that. If you are looking for more horsepower than, bolt on performance is probably what you are after. Less expensive and does the job quite well. This is stuff like timing gear sets, cams, manifolds and FI systems, exhaust headers, and computer reflashing. Look for aftermarket performance on line(you can find a ton of stuff for Fords) and pick the one that best fits your budget. Let me know if you need advice on what you find.
May 21, 2010 | 1997 Ford Mustang Cobra
How to adjust the toasting time on the preprogram
your better off going back to the factory setting. Call turbo chef but here you go this is how you re-program the thing. Remember i took the time to give you these directions. Please take the time to leave a review
PROGRAMMING
Edit Mode
The EDIT MODE enables the operator to manually alter
recipes and the cook cavity temperature (CCSP).
To access EDIT MODE:
1. Simultaneously press the UP and DOWN keys.
2. When prompted, enter the access code “9” and
then press the ENTER key.
Altering a Recipe
Most NGC (Tornado) oven models contain 128
unique recipes. The display shows two (2) pages each
with eight (8) recipe groups. Each recipe group contains
eight (8) recipes. See Figures 11 and 12.
To alter a recipe:
1. Enter the EDIT MODE (see page 16).
2. Enter the access code “9” and set the CCSP. The
screen displays the first set of eight (8) recipe
groups. To access the second set of eight (8)
recipe groups, press either the UP or DOWN key.
3. Select the recipe group that contains the individual
recipe you wish to alter. Select the recipe you
wish to alter by pressing the soft key corresponding
to the recipe item. Figures 11 and 12.
4. Use the UP and DOWN keys to navigate through
the recipe settings. Use the keypad and ENTER key
to alter any of the following three (3) parameters
(see Figure 13):
a. Cook time
Total duration of the cook cycle. Enter the
desired time and press ENTER.
b. IR element temperature (IRSP)
The temperature the lower radiant element
will maintain during the entire cook cycle.
Valid temperatures are between 500ºF (260ºC)
and 1150ºF (621ºC).
c. Events 1…6
Use the keypad and ENTER key to enter values
for % TIME, % AIR, and % WAV.
o Sum of % TIME for all events must = 100.
The operating system will not allow a
combination of events not equal to 100%.
o The % AIR parameter is valid between 10
and 100%.
o The % WAV (microwave) parameter is valid
between 0 and 100%.
5. After making changes, test the recipe by
pressing the TEST soft key. Once the oven has
warmed to the CC set point, press the TEST
soft key again to begin the test cook.
6. Once satisfied with the recipe, press SAVE to
permanently store changes.
7. Press the BACK key until exited from EDIT MODE.
Jan 14, 2010 | TurboChef TORNADO Electric Oven
What is the importance of agreeing to a budget and operating within it?
before building a pc you need to know your budget bec. parts have different prices, high ends are more expensive, if you buy expensive parts with limited budget, you would end up short in cash
Oct 19, 2009 | Anuman Interactive Home Budgets for...
Primavera financial reporting
Have you considered creating a regular export from P6 and using Access or some other reporting tool to generate your reports? I could set you something if I new the specifics of what you are trying to get.
Feb 10, 2009 | Primavera Contractor 6.1 Full Version for...
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How do you reset to mfg settings or set red/blue convergence?
I purchased mine about 5 months ago. Ive been researching and playing around with the remote. This will help you on the way. With the set off, press "Mute", 1, 8, 2 then turn the tv on. This will bring up the main settings, dont change any values on any page, unless you write the origonal values down first, because the total reset doesnt return everything to a "factory" preset. Scroll down to reset and press the enter key. I havent come across any owners or service manuals, and support is slim to none. I wrote a review for the same model on a wal-mart site I believe, and it explains adjustments in more detail. If you want to try to figure out the buttons for yourself, while the tv is on, press "Mute 1, 8, 3" this is another set of adjustments for finer detail. If you change an adjustment here and your not sure, just press the exit button. To save your adjustments in the convergence mode, press and hold the enter button, it should flash a few times and center itself on the screen. If you make a mistake in this mode, the total reset I mentioned first should get you back on track. If you find anything out or have a question, feel free to write me at Silverado1st@aol.com
Jan 02, 2008 | Televison & Video
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
Help please stuck in service menu
You should have purchaced the service manual before you went into the sevice mode, as the service mode is a dangerous place to be if you do not know anything about it. You can get the service manual from www.servicemanuals.net for about 20 bucks or so. A lot less expensive then a serviuce call I would think.
Aug 02, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Computers & Internet Logo
97 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
