Question about HP 1040 Plain Paper Inkjet Fax
Jammed document This is regarding HP 1040 Fax machine. It's saying Remove jammed paper and press Cancel. There is NO paper in the machine. We can't receive any faxes. Please help.
  • 8 more comments
  • Anonymous Nov 16, 2008
    Fax will send to one number but not to another.
  • bham403 Nov 25, 2008
    I have tried to clean the contacts on the cartridge but this did not work.
  • dp_little Dec 01, 2008
    Hp1040 fax machine saying remove paper jam and prees cancel. no papaer in machine, can't copy or send faxes.
  • Anonymous Dec 01, 2008
    Same problem. Can't send faxes. Might get passed first page but then it stops and gives paper jam error message - but there is not paper jam.
  • arm5 Dec 08, 2008
    Can't receive faxes due to a non existent paper jam.
  • Anonymous Dec 11, 2008
    jam paper in HP 1040 fax machine
  • Anonymous Mar 12, 2014
    there is no paper or pieces anywhere but it says remove paper jam and press cancel
  • Anonymous Mar 25, 2014
    i had some problem with copy.it was about paper fetching.i opened the machine and checked pad & pickup and clean them.after that when i turned it on i got a error : remove document press stop.i did it but still i have the error and copy key doesn't work.please help
    i had a problem with my panasonic fl 612.it was about coping.the paper fetchin had problem.so i opened the machine to check pad and pickup.i just opened top cover and paper holder and cleaned pickup and checked the pad.after that when i turned it on i got a new error massage:remove document,press stop!i did it but i got no result.i still have the error and the copy key doesn't work.please help me.
  • Anonymous Mar 29, 2014
    It is same size paper as always, but won't fax or scan
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
Posted on Aug 12, 2009
We had the same problem and there was NO PAPER IN THE MACHINE! We opened the front, reached down to the right side, pulled up on the little purple roller holder, removed the roller and put it back. The machine thought we cleared the jam and it solved the problem. Seaford, DE
Posted on Aug 02, 2009
Says I have a paper jam but I do not. Can't send faxes or make copies. Please help this is a HP1040 fax machine.
Posted on Nov 30, 2008
I believe that this is a board level problem as I have seen many 1040's with this very same problem and I have taken them apart and cleaned and reconditioned the rubber rollers that feed the paper thru with no real luck. I have also noted that the sensor that detects the paper does not appear to be functioning either when activated or deactivated the srror state does not change. I therefore feel that this is a main board defect.
Posted on Aug 16, 2007
    Problem Solver:
  • 12 Answers
Try cleaning the paper rollers. If they're worn or dirty, they can't grab paper, and the machine gives a jam error, even though there's no paper jammed. This is a common problem. Use alcohol and a clean lint-free cloth (don't use paper towels).
Posted on Feb 06, 2007
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Have an HP 1040 Fax machine, whenever I try to copy, I scans fine, but then it brings up message that says remove jammed paper and press cancel even though there is no paper in it and when I do this, it...
The paper could be as small as a pin head stuck at one of the rollers. get a can of air and manually move the rollers while blowing them and blow all openings around the paper feed area.
Oct 23, 2012 | Office Equipment & Supplies
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
CHECK 5100
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
Feb 20, 2012 | Office Equipment & Supplies
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
Fax
Often, this type of problem is caused by the paper sensor which is nothing but a small switch activated with the presence of the paper(s) pressing on it, It would look like a small tab/lever that would move (to activate the switch) by the paper pushing against it. You would have to inspect this lever/switch and determine if it would move freely. It is very rare for the actual switch to go bad, often it would be just the tab/lever not depressing deep enough to engage said switch.
Hope that this beof initial idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 02, 2008 | HP 1010 Plain Paper Inkjet Fax
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
My hp 1040 fax will not send a fax or copy a document. It tells me that there are jammed papers when that is not true.
check the paper tray,maybe some of the sensor stuck or dirty,just try to clean paper tray with compressed air.
Feb 17, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Plain Paper Inkjet Fax Logo
616 people viewed this question
Clive
Clive
