I wanted a printer that would copy one side and two sided pages they supplied me with a c7280 but i cannot find pout from thebasics guide how to get a two sided copy
  • Anonymous Mar 02, 2009
    Canon MX850.
    Not able to PRINT BOTH SIDE of one paper
    Problem Solver:
  • 14 Answers
For the two sided copy you need a duple facility...in printer ..
duplex is a mechnisim if it is in printer on it with printer setting
Posted on Dec 02, 2008
Two sided copies
that machine does not have an automatic duplexing capability
what you have to do to print both sides of the paper is in the print selection highlight print pages 1,3,5 etc and when finished turn the pages upside down and in backwards , the print pages 2,4,6,8
in the pages selection -print odd pages then when done print even numbers
Jun 17, 2017 | HP Officejet 6200 All-In-One InkJet...
How to copy 2 sided
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP Office Equipment & Supplies
How can double sided print
HP3350MFP - Duplex Printing/Copying
Hello, The HP3350 does not support automatic double sided printing. The HP3390/3392 printers support this option. In order to double side on the HP3350 a manual duplex will need to be conducted, which means running page 1 through the printer, flip the page over and print page 2 for the reverse side. It may be necessary to experiment a few times to achieve the proper printing orientation. You can download a copy of the users guide from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=ca&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=1161389
Jan 15, 2011 | HP LaserJet 3055 All-In-One Printer
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
On the X4850 2 sided printing I am trying to make copies of a 2 sided documet , in other words front and back , it only scans one side and than I have to flip it , I need 200 copies dont want to flip ,...
Download the user guide and follow the steps on page 81 of the manual:
http://safemanuals.com/user-guide-instructions-owner-manual/LEXMARK/X4850-_E
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 05, 2009 | Office Equipment & Supplies
7x9 copies getting cut off on right side of page.
Have you tried to make a copy by using the by-pass tray or manual feed tray. If the copies come out OK then the problem may be that the paper tray guides are not alined crrectly for the paper you are tring to use.
Apr 01, 2009 | Canon imageRUNNER 5000 Copier
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
93 people viewed this question
jasbo
jasbo
