Question about Brother MFC 210C All-In-One InkJet Printer
Printer won't work - have tried the troubleshooting suggestions
My printer will not react to print command - have turned off the computer and restarted - have replugged the printer and still no luck.
  • 7 Answers
For Brother MFC210C Printer Fax Copy Scan
Posted on Dec 03, 2008
  • MJ Hession Dec 03, 2008
    1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
    FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
    2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
    3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
    4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
    5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
    6) Press the 9 key twice to return to the standby state.
    Carry on printing !!
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
My printer won't shut off or print, lights keep blinking, computer won't boot if printer is on, must pull the power cord. Does my printer have a short in it?
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Nov 06, 2011 | HP DeskJet 970cse InkJet Printer
Printer error, needs troubleshooting - printer worked last week, now it hold prints in cue, windows troubleshooting is not solving issues 7310 hp office jet, tx
Hi
Maybe the print spooler service had stop and needs to stop and restart again. Please try this solution.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
If not, try to set up or add once more the printer to correct any printer driver corrupted files.
Or if not, uninstall and reinstall the pirnter driver and then, add once more the printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 11, 2011 | HP OfficeJet 7310 All-In-One InkJet...
My computer system Microsoft XP.. I have a desktop icon to open the word processor (Microsoft Word)... When I click on the icon a box opens indicating "unsupported format." I then click cancel and it...
I suggest you start by uninstalling Word (control panel | add/remove software) and reinstalling it. You can also try reinstalling the printer driver. Ask again if this doesn't resolve your problem.
Simonides
Oct 10, 2009 | Computers & Internet
The printer does not print when commanded
try and copy something and check if that comes out blank or not..........if it comes out fine then just follow the troubleshooting guide on www.kodak.com/go/itg .
Dec 23, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to adjust print head temperature on TEC B-452-HS12-QQ
it depends if you are working with driver, label software or escape commands. If you are working with escapes you can try with command AY, refer to the programming manual.
If you are working with Seagull driver you can adjust the print density in OPTIONS
Oct 28, 2008 | Toshiba TEC B-472 Thermal Label Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
