Question about Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
I have a Brother Fax machine 2800. On the screen it shows SLEEP the date and F/T. When someone tries to send fax it only rings and it does not receive fax. How do i remove the sleep mode.
  • 4 Answers
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Posted on Dec 02, 2008
Fax machine in sleep mode
It should wake up if a fax is coming in or you send..
Press the Energy Saver Key
Jan 22, 2009 | Brother IntelliFAX 2800 Laser Fax
Intellifax 2800 fax machine
my suggestion would be to down the manual from brother.com
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Our fax doesnt want to recieve it sais sleep mode
have you tried to turn it of then on to reboot the fax machine! if that will not work you may have a bad main board
Jan 10, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax machine sleep mode
have you tried to unplug the machine from the wall and then plug it back in this reboots the machine
Dec 23, 2008 | Brother IntelliFAX 2800 Laser Fax
The fax machine is in sleep mode
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line . Filter makes no difference.
Nov 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Screen shows call Brother, code 77
You have a problem with the FUSER UNIT.
Nov 07, 2008 | Brother IntelliFAX 2800 Laser Fax
Setup
Yes, just set the receive mode to "manual" the machine will then just ring when a fax is incoming and not print. It may become annoying after a while because the sending machine will try to send numerous times. You can get around this by setting the ring volume to mute.
Jun 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Disable receive mode on FAX-2800
NO the best solution is to turn fax machine off after hours
Jan 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
599 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
