Question about Maxtor DiamondMax Plus 9 200 GB Hard Drive
My hard drive does a clicking sound
Basically, it occurs randomly... It can not happen at all while I'm on the PC, it can occur 5 minutes after I turned it on or 5 hours later. What happens is that my hard drive starts making a "clicking" noise over and over again, freezing my computer for a couple of seconds, then going back to normal, and within the next 10 seconds repeats what it just did, until a critical error occurs (blue screen) or my computer just restarts. Now I would really appreciate it if someone could enlighten me as to whether this is a hard drive problem or a motherboard problem (the latter being a suggestion made by my girlfriend). It appears that the hard drive starts skipping, screwing up everything but... what can I do? do I have to buy a new hard drive? Motherboard? Please help :-S
  • 624 Answers
What?s going on: Your hard drive is suffering from read errors. It?s going to a spot on the hard drive to read some information it needs and can?t read it. Once that happens the built-in procedure is for the hard drive controller to put the read heads back into the home position (the clicking noise you hear) and go back out to the section it couldn?t read before. It will continue to do this a set number of times and then usually give you a read error or a blue screen of death. What to do: -You can try reformatting your hard drive in the attempt to get the operating system to block out the sectors it can?t read. Sounds nice in theory, however, if you have bad sectors developing others will probably follow which means you?ll have the same problem again. If money is a serious issue you can try this but chances are this will only be a temporary fix. -Replace the hard drive and reinstall your operating system. At $80 this is likely to be your best option if stability is your primary concern. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Jan 30, 2007
  • 95 Answers
Most likely it has degrading heads. This site should help you diagnose the problem.
And definitely you shouldn't store any valuable data on it.
Posted on Nov 29, 2008
Data Recovery Hard Drive Not Mounting
> no beep, click or error sound occur, but the drive is simply not mounting ...
> . I need the data on it
Too late! The disk-drive has "died". Your data is GONE.
Nov 11, 2013 | Western Digital WD5000BMVV 500GB 5400 RPM...
Dell Vostro 3500 suddenly shut down, start up and works fine, after 2 minutes turn off without any warning message this happened after i installed bios upgrade A10 from dell.com
this is happening because of bios upgrade but not in a bad way. May be there is a hardware problem just starting so new bios upgrade is detecting that and thats why its restarting.
basically sudden shut down occurs in either cases- Fan not working or hard disk(or RAM) gone bad.
my advise is to contact dell customer support and they will guide you thru trouble shooting steps.
they will guide you if your warranty is not there.
Jan 02, 2011 | Dell VOSTRO 3500 Notebook
My dell inspiron mini 10 is making a random static noise
Muting does not mean turning off the speaker which means there can be occasionel static.
It occurs more if the is a magnet near!!
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Makes continuous squeaking noise when switched on
Dear User,
This is symptoms of RAM fault that why at startup while verifying the RAM computer give sound.
please RATE my answer if you are satisfied
Sep 08, 2009 | Acer Aspire 1642WLMi Notebook
Xbox 360 controller turns off at random, yet has new batteries
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries(or more specifically - bad batteries) - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. I'd recommend a recharge while you play pack. ALWAYS by the official products too. They're much more reliable and aren't prone to this kind of behaviour.
Jun 26, 2009 | Microsoft Xbox 360 Controller
External hard drive emits noise and disconnects within 60 seconds
please try changing the hard disk compartment and thanks for your question
May 20, 2009 | Computers & Internet
Maxtor DiamondMax Plus 9 200 GB Hard Drive Logo
142 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
