Question about ASUS CROSSHAIR Motherboard
Computer won't turn on.
I switched to Asus Crosshair Mobo. Put in athlon 6400+ x2 processor. Connected everything right. when i power it on, it only stays on for like 7 seconds or so, then turn off. Tried turning it on without the CPU, it works fine. Tried my CPU on other mobo, it works fine too. help please.
  • htpintal Dec 02, 2008
    I tried my Processor and the fan that comes with it, with biostar motherboard it works fine.
    Scholar:
  • 172 Answers
This sounds like an overheat problem, is your cooling fan working properly, also the processor you are using is a powerful one, so needs a cooling fan much more powerful than the lesser powered athlon 64 processors.
Posted on Dec 02, 2008
  • Chris Fell
    Chris Fell Dec 02, 2008
    In that case it is a faulty motherboard, beneath the processor socket are a series of small temperature sensors which sometimes malfuncfunction. Suggest that if the board is new, you should return it under a "Faulty under warranty " return basis.
    One other option to confirm the problem will be to fit a lower spec' cpu if you have one knocking around to test it under that platform.
    Chris
M2NPV-VM - Fastest Processor?
If ASUS says that is the fastest that will work on the board, then they should know. Incidentally processors don't run at 95 volts although some run at a power consumption of 95 watts. Besides there is not a faster AM2 CPU than the one you mention.
Jan 30, 2013 | ASUSTeK COMPUTER Asus M2npv-vm Motherboard...
I want to install windows 2000 0n my E machine with a athlon prosser. will their be a problem
Everything should be fine there in installing Windows 2000 on that computer with a Athlon processor. Just make sure you have all the drivers for your computer including the MOBO, video card and others.
Apr 29, 2010 | AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2...
CPU overvolted and burn using 8pin eps12v cable on crosshair
no i dnt think so some time due to manufacturing defects this happens the new one wont burn unless and untill u over volt it.
Jan 31, 2010 | ASUS CROSSHAIR Motherboard
Procesor speed
Well, I would start by going to the ASUS web page and look up your specific motherboard. Here is the link right to the board---
http://usa.asus.com/products.aspx?l1=3&l2=117&l3=0&l4=0&model=1283&modelmenu=2
the specs listed at ASUS's site don't say specifically"how many Gz processor can my mothereboard suport" although they will point you in the right direction. Open up the site on a seperate internet page if you haven't already and look at if for me. Do you notice where it mentions the Socket types that it supports in the CPU section?? Basically the page is telling you what type of processors it will run. I believe the Athlon 64 x2 is the fastest out of what they have listed, although i did not look up the specs. You should be safe buying any speed Athlon 64 x2, Athlon 64 FX, Athlon 64 or Sempron processor. Hope that this was helpful, if it was could you please give me a good review? Thanks.
Mar 23, 2009 | ASUS CROSSHAIR Motherboard
Athlon 64x2 5200+ to Athlon (black edition)64x2 7750
ok
it's compatibel with any athlon processor
but not the black edition one
well, the problem maybe your chipset is not compatible with the black edition processor
second, let's think your chipset is compatible, but your bios don't. then you must to flash your bios with updated bios
and third, your black edition processor is broken
please rate and gimme more specific specification of your mobo
Jan 22, 2009 | AMD Athlon 64 X2 4200+, 2.2 GHz...
I swithed to asus crosshair motherboard. put in an athlon 6400 x2. Connected everything right. When i turn the power on, it stays on for just like 7 seconds then turn off. at the back the lcd says comp...
HAVE YOU CHECKED TO SEE IF MOTHERBOARD SUPPORTS THAT EXACT CPU.OR YOU MAY NEED TO CHANGE A SETTING(S) IN THE BIOS.TRY NOT USING AUTO DETECT FOR CPU MANUALLY ENTER INFO.RICHARDM69
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
Computer won't boot up
Make sure that your power switch is connected to the correct pins on the motherboard. The LED you see lit may be the stand-by power indicator saying it has power and is waiting for the signal from the power switch.
May 06, 2008 | ASUS CROSSHAIR Motherboard
Motherboard Issue
Hi Tomokato,
This maybe nothing but the first thing I checked is the CPU.
Supported CPU list through Asus web site for M2N-SLI
(Click on this link). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M2N-SLI
The first supported 64 X2 is;
Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2
Second CPU supported;
Athlon 64 X2 3600+ (DD),1MB,65W,rev.G,SocketAM2
The CPU that you are using is not supported.
Since this is a new CPU, you might be able to exchange it for the Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2.
Link to Asus main web site for M2N-SLI.
http://support.asus.com/download/download.aspx?modelname=M2N-SLI&SLanguage=en-us
Suggest you add the above link to you're favorites.
Even you're memory is not supported. As seen in user manual page. 2-13.
Have more questions, feel free to ask.
Mike
May 01, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
ASUS CROSSHAIR Motherboard Logo
139 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
