Question about Invicta Dive/Sport - SPEEDWAY CHRONOGRAPH WHITE FACE 9211
I have an Invicta 5103 mechanical wind chrono and the large second hand will not zero out on the 12
  • 183 Answers
To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it.
Posted on Sep 18, 2009
How do I wind my Invicta 1805?
My very brief research shows that the Invicta 1805 watch is driven by a Japanese quartz movement. That would certainly explain why you're having trouble winding it.
The easiest check for quartz vs. mechanical is to observe the second hand. If it pulses only one time per second--i.e., jumps one second at a time--then you're looking at a quartz movement (I'm ignore the rare and expensive mechanical jump movements). If it looks like the hand takes 4 or more little jumps to get from one second to another, you have a mechanical movement.
Dec 01, 2012 | Invicta 1805 Watch Mens Russian Diver...
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
Invicta 6423 I can 't match the time on the hands and the digital watch
Press mode button until only digital seconds are displaying.
Hold both chrono buttons until you see the word sync on display
Press each chrono button until hour and minute hand is at 12:00
Press mode button
Aug 18, 2012 | Watches
Zero in second hand
Easier than you think.Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Aug 29, 2010 | Invicta Subaqua Noma Iii S
My new nixon 42 20 when i reset the chrono the second hand doesnt go back to zero it goes to 16 seconds past how do i sort this problem its annoying !
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Aug 20, 2010 | Nixon 4220 PU Chrono Watch Black
My Tag Heuer chronograph will not reset to zero.
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
Feb 11, 2010 | Tag Heuer Aquagraph CN211A wristwatch
The second hand on my invicta chronograph watch doesn't reset to zero
Dec 26, 2009 | Invicta Subaqua Noma Iii S
The large second hand for use in the chrono mode rests at the 11:58 position and resets to this position instead of 12:00?
pull out the crown to either the 1st or 2nd position and use the top and bottom buttons to zero out. please rate my solution
Oct 10, 2009 | Invicta Subaqua Noma Iii S
Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
Problem with the large chrono indicator
Pull out the crown to the #2 position then push the start /stop button to move the second hand up to zero
Dec 09, 2006 | Skagen Men's - PERFORMANCE TITANIUM CHRONO...
534 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
