Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
Vertical Lines on Picture, no Video.
Customer does not believe that the set was knocked or hit, yet this problem has surfaced. Anywhere between four and eight vertical lines are on the screen.It looks like a video sync problem. Advice. Thank you
  • 7 more comments
  • Brendan Noone Jan 30, 2007
    Here is an image taken with satelite video feed.
  • Anonymous Dec 09, 2007
    this has happened three times, we've repaired it each time at a cost of 700$ and it keeps happening!! we have heavy duty surge protectors, so that can't be the cause, it just works one day and not the next
    its a total piece of junk!!!
    i don't recommend anyone buy this tv--or lg--ever
  • Anonymous Feb 21, 2008
    vertical lines
  • TimIre Mar 07, 2008
    I have tried all fuses on internal boards.
    I have tried rmoving and reseating upper and lower Y boards no Luck.
  • Anonymous Apr 24, 2008
    colourd lines on picture
  • Lil Pup Apr 26, 2008
  • ostrom5150 Apr 30, 2008
    Same thing for my 50 inch RU-42PX11 Picture is identical! What happened???? How do you fix this???
  • neil marriott Jun 04, 2008
    have the same problem with nec.noticed that if cool warmth applied went away until set turned off.tried freezing could bring lines back again .tracked down to certain area.thought might have been dry joint.but problem got worse.now is just coloured lines .every thing else works okay.when go to wide view lines will open up and close as you adjust screen.
  • karlberg45 Dec 23, 2008
    I have same problem
I have been advised by a TV repair shop that this problem is teh Lower Scan Baord gone faulty, is this true possible.
Posted on Mar 05, 2007
Dry solder joint on the main pcb
Posted on Feb 23, 2007
Horizontal bright line sound is fine will sometimes go normal with hit to side of TV
Sound like cold solder joints on the vertical output ic. The vertical output ic is usually a inline 7-9 pin chip that begins with la prefix. Not hard to repair at all just be careful not to touch anywhere near the anode leads to the picture! Basically it will knock the **** out of you. lol..
Oct 17, 2010 | Toshiba CF35E50 35" TV
MAY HAVE BEEN HIT BY LIGHTNING. BLACK SCREEN AND 2 COLORED LINES
Replace the deflection board. Sounds like the vertical deflection was knocked out thats why you still have sound. You can get replacement deflection boards from www.tvrepairworld.com
Aug 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
HP Pavilion Laptop - vertical lines on screen from top to bottom
this will more than likely be a video card issue. The bad news, on laptops, everything is integrated into the motherboard and and you will have to replace. Getting to the motherboard can be a pain.
Aug 06, 2009 | HP Pavilion zd8000 Notebook
Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Model 27mt5005d37 magnavox
I believed Tv has a vertical resolution problem. Some components is fauly and needed to change.Well refer to your nearest repair shop or agent.
Regards
alan
Mar 02, 2008 | Philips Magnavox 27MS343S 27" TV
Sony gv-27v42 27" tv picture cuts out after a few minutes
Vertical lines down the center only means that you have a loose connection on the Yoke. Re solder all the connection on the yoke and where the yoke connection meets the main board.75481bd.jpge307a54.jpg
best regards
Circuitcity
Dec 21, 2007 | Sony KV-27V42 27" TV
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
LCD SCREEN
Do you have a picture showing in the viewfinder when the LCD is closed? If not, it's a bad CCD and I believe Canon will fix that for free if you call customer service.
Oct 15, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Open Questions:
See all LG RU-42PX11 42 in. EDTV-Ready Plasma Television Questions
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
434 people viewed this question
Steve Allison
Steve Allison
