Question about Whirlpool Duet GHW9150P Front Load Washer
Door won't unlock
Door doesn't unlock when pressing all appropriate buttons
  • 370 Answers
It is either your door lock mechanism or your CCU (central control Unit) Replace the door lock mechanism first. if thats not it its your CCU.
Posted on Dec 02, 2008
Key won t unlock doors
lost the other fob>>> ?????
never own a car with 1 fob.
and if one fob messes up, the battery inside is dead. (or worse)
if just lock fails the button is bad, if one fob false, and they do
its just cheezy switch. (can be cleaned)
use the other FOB, if it fails, post.
Jan 25, 2014 | 2007 Honda CR-V
2002 rav4 doors won't unlock only lock
Change the battery in the remote key.
Sep 25, 2017 | 2002 Toyota RAV4
Door doesn't unlock, won't start a program
it might just need an update,if not the main board could be going to fail hope not ,not cheep
Nov 03, 2017 | Zanussi WJD1257W Front Load Washer
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
I have the door bell style wall button-how do I unlock the unit so the remotes can be synched? I have pressed green button on back of unit with remotes but they won't operate the door.
You don't unlock anything to program the opener for the remotes. If everything is working you do this:
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
Jul 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
Unlock button doesn't work
need new switch about 45$ at junk yard
Feb 12, 2012 | 1999 Oldsmobile Silhouette
Drivers door doesn`t unlock when the weathers cold or it`s raining
weird this one, has a transistor playing up but where ??
Oct 05, 2008 | 2001 Volvo S60
Whirlpool Duet GHW9150P Front Load Washer Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal De
