Question about Onkyo TX-SR603X Receiver
TX-SR603X cuts off at higher volume levels
My TX-SR603X shuts off at higher volume levels. This has happend before but went away. It is now doing it again. I also tried doing to automatic set up with the mic. When it got to the left rear speaker, it shuts off. I tried unhooking this speaker but it still happens. Any suggestions please? Thanks
  • 1 more comment
  • Jeff Henderson Jan 30, 2007
    That sounds like that would require it to be repaired by a technician. Is that right?
  • Anonymous Jun 30, 2008
    SAME PROBLEM WITH 2 ONKYO RECIEVERS, I HAVE NO IDEA WHAT IS GOING ON
  • Anonymous Jul 01, 2008
    I HEARD THAT 90% OF THE TIMES ITS A BAD SHORT IN ONE OF THE SPEAKERS. TO HOOK ONE SPEAKER AT A TIME AND TURN IT UP UNTIL YOU FIND THE SHORT OR THE FACEPLATE TO THE ELECTRICAL UNIT TO YOUR WALL OF YOUR HOME COULD BE ANOTHER PROBLEM.
The overload board is failing.
Posted on Jan 30, 2007
How can I run a turntable through the onkyo tx-sr603x?
Look on the back of the system, if there is phono input, that is what you can use to connect the turntable without using an external pre amp
Aug 27, 2011 | Onkyo TX-SR603X Receiver
I have an onkyo receiver tx-sr603x. I can get
audio amplifier´s damaged need to be replaced
May 25, 2010 | Onkyo TX-SR605 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
Power outage overnight. Now, Onkyo TX-SR603X no
Depending upon the type of power outage, you may have more of a confused receiver than a defecive one. Try unplugging the unit for an hour or so to see if that resets the whole thing back to "normal". If not, then further investigation with a scope or logic analyser will be required to determine whether the problem is with the internal CPU or a defect on the data lines. Unless the reset works, this is not likely to be a DYI repair.
Dan
Mar 28, 2010 | Onkyo TX-SR603X Receiver
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
It keeps shutting off
If you have zone 2 active with the level turned up too much it will cut out the whole unit. Try disconnecting zone 2 speakers, then turn the volume level way down on zone 2 and it should stay on if that is the problem.
Jan 02, 2008 | Onkyo TX-SR803 Receiver
ONKYO AV RECEIVER TX-SR603X
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Oct 14, 2007 | Onkyo TX-SR603X Receiver
Onkyo TX-SR603X Receiver Logo
220 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
