When I print my excel spread sheet on 11X17 paper portrait mode, it shifts the print about 2 inches to the left. Print preview shows fine. Printer HP color laserjet 5550 dn
    President:
  • 8,637 Answers
It sounds like you need to do a page setup and adjust the margins. Hope that is the problem. Other wise I don't think you would get the shift. Bud
Posted on Jan 06, 2009
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Office 2007 excel is not printing what is in print preview. Why?
There are sometimes that a printer won't print what's in print preview especially if it's not compatible with the paper size that you have set up in your printer. Try to check the printer's properties. Press CTRL + P and go to the properties of the printer. Check the paper or page set up. It should be compatible with the paper set up in your excel sheet.
Mar 21, 2011 | HP Office Equipment & Supplies
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
The HP4240n automatically prints two (2) copies of my Excel documents when only asking for one (1). Does not do this with other applications
Open up your spread sheet.
Click File on top left
Click Page Setup
Click Options
Shows Document properties...click on advanced
Shows paper size....A4
then copy count....this is probably set to 2, click on it and set to 1.
Sep 22, 2009 | HP LaserJet 4240n Printer
Photoshp CS2 print differnet photos on one sheet photo paper
for printing multiple photos in different layouts, photoshop might not be the best program.
You can howerver do it, here is how:
Open a new document with the preset letter (if your printer prints letter format) or Din A4 (if it prints A4 pages).
Open the three (or more, or less =) photos, so that you have four windows in photoshop (one is the blank page)
now with the move tool (tool palette -> top left corner) drag and drop the photos onto the blank page you created.
They might be too big (or too small). In order to change that, hit strg-T (if youre mac thats apple-T).
This will show a frame around the photo, where you can drag the corners to enlarge or shrink the photo. Hold down shift while doing that so the picture stays in proportion (youll see what i mean).
When the pic is the right size, hit the okay button on top of the workspace or just hit enter.
arrange your photos and hit File->Print with Preview (or something like that)
Now you can see how the printer is going to print the page.
If its cut of, youll have to go to Page Setup and set it to Landscape mode (or Portrait)
When you hit okay, Photoshop might tell you that the printer will cut off edges of your picture. This usually isnt true because the edges of your page should be white anyways (most printers dont print to the border of the page, so calculate 1,5 cm or so)
so just hit proceed and print
I hope this wasnt too complicated, come back with more questions if you want =)
also, be sure to try picasa from google for organizing photos (i think you can print from there too)
Jan 01, 2009 | Keystone Adobe Photoshop CS2...
My Pages Are Printing Off The Page
If you still have your printer manual. Look up the instructions for calibration. That will fix it.
Jan 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Booklet printing on 11x17
In Print Settings make sure the original size is 8 1/2 by 11 and print out size is 11 x 17
Nov 01, 2008 | Ricoh Aficio CL7200 Laser Printer
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
139 people viewed this question
k24674
jasbo
jasbo
