Question about Epson C64 InkJet Printer
Alignment printer prints ok but about 1/2 inch to the side when paper put in on far right. shuffling it to the left a bit is very hit&miss, how do i correct this error? TIA
  • Mike Gagg
    Mike Gagg Jan 30, 2007
    didn't change anything but thanks
    President:
  • 2,961 Answers
Check the paper size in printers properties, it may have altered. If not disconnect printer, remove printer driver from add/remove programmes. Re install driver and reconnect printer when prompted. It should now be ok
Posted on Jan 30, 2007
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but...
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Jan 01, 2014 | Minolta magicolor 2300W Laser Printer
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
HP Pro 8500 printer has carriage jam. I have opened every door and there is no paper jam.
Sometimes the paper gets caught inside the printer all the way to the right (or left) of the print carriage. You will miss seeing it because the print carriage has moved the jamed paper to the right (or left) out of view. Carefully and manually move the print carriage to the opposite side and you might find small pieces of jammed paper there.
Jul 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Print output on left hand side is missing
see if there is a local repair center, Sounds like the wiper on that side could be out of alignment. and hitting the drum early there for possibly wiping it before it has time to hit the paper and transfer it over.
Nov 09, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Part of print is missing (far right or far left side),instead ver
Sounds like you have a torn/missed fixing film. look up over the fixing unit (the one that gets one) and try to find a gray tu, it should be complete, from left to right and not torn. no parts should be missing. if one border is like orange or missing then your problem is the fixing film.
Jan 25, 2009 | HP LaserJet 1018 Printer
Printing blurred
H'mmm - new one on me , and I'm ***** old. If it was all blurred I would blame a faulty capacitor on the main board putting noise on the line - but the first inch? Check the track (where the print head travels along) and make sure there is nothing to cause the paper to be a bit low at the left end. Report back on what you find.
Jan 12, 2009 | Epson Stylus 830U InkJet Photo Printer
White bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Epson C64 InkJet Printer Logo
19 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
