Question about Compaq Computers & Internet
Lost keyboard driver
Key board doesn't work
  • 1 more comment
  • John Anderson
    John Anderson Jun 19, 2012
    keyboards are plug and play devices so shouldnt need a driver but if you tell us what model of keyboard it is will have a look for you.
  • Shan Jun 21, 2012
    First, I want thank everyone for their help!
    John, I thought that they were too. But HP who is the manufacturer has
    keyboard dwn loads for them. I searched for the driver off the
    serial number LE10420401 (Compaq Presario-windows 7) and found an artical
    that said the mouse software is bad-hence that effects the keyboard.
    Now I'm really confused!
    I dwn lded off HP site another driver-but keyboard still not working.
    Tried Ctrl Alt on the keyboard and the start menu pops up which seems to prove
    keyboard is working but for some reason is not fully able to do more.
    Will appreciate more feed back-I hate having to use the on scr keyboad as it
    slow!
  • Shan Jun 21, 2012
    forgot to add that mouse curser 'floats' on the scr-doesn't that the mouse software
    is corrutpted?
  • Compaq Master
  • 27,725 Answers
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
if your computer came with a motherboard disk the drivers could be on it
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
hope this helps
Posted on Jun 19, 2012
  • 3 more comments
  • Brian Sullivan
    Brian Sullivan Jun 22, 2012
    clean the underside of the mouse where the light is if applicable
    you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
    click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
    click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall in xp
    click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
    make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
  • Shan Jun 22, 2012
    Brian, I did all that before posting the first time. I should have mention that-it's SOO slow using the on scr keybraod so am keepin posts minimal.
    BTW tried the web page you kindly provided. Nothing changed..
    I'm starting to think its a software mouse/keyboard issue...scratching head
  • Brian Sullivan
    how old is the mouse and keyboard
  • Shan Jun 22, 2012
    About 1 1/2 years old
  • Brian Sullivan
    should have asked this first are they ps2 or usb connected mouse and keyboard devices and what brand the mouse and keyboard might be faulty have you tried uninstalling both keyboard and mouse restarting your computer then reinstall them
    if you use safe mode both devices should work
    restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
    If done properly the user should get to a screen similar to the below screen.
    Select the option for Safe mode command prompt only
    Windows Advanced Options Menu
    Please select an option:
    Safe Mode
    Safe Mode with Networking
    Safe Mode with Command Prompt
    Enable Boot Logging
    Enable VGA mode
    Last Known Good Configuration (your most recent settings that worked)
    Directory Services Restore Mode (Windows domain controllers only)
    Debugging Mode
    Start Windows Normally
    Reboot
    Return to OS Choices Menu
    Use the up and down arrow keys to move the highlight to your choice.
    select safe mode
    click start right click on computer select properties device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
    click start right click on computer select properties device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
    right click you will need to update the driver
SOURCE:
Few keys not working on keyboard
Should replace key board. Moisture and keyboards do not mix.
Jun 14, 2017 | Microsoft Natural Ergonomic 4000
Couple of key on my labtop samsung rf510 doesn't work
need a new key board lucky it is just the keyboard spillage usuly do:s more damage
Dec 25, 2012 | Samsung Computers & Internet
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
Keyboard locked on m14x laptop
replace the key board it doesn't cost so much
Mar 10, 2012 | Dell Alienware M14x Notebook
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
Some keys in my keyboard of hp mini 1000 are not working properly
how much would i pay for a change of keyboard f ever it doesn't really works? please send me answer on my email. i really need this to fix. i just borrowed this mini notebook. or any other options to fix it manually by my self? my backspace doesn't work. send me answers on my email please. tumulak_myra@yahoo.com
Oct 08, 2011 | HP Mini 1000 Netbook
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
My keyboard stopped working after my dad threw a pillow on it absent mindedly, and it messed with my normal keyboard now it just doesn't work at all, its really annoying, i tried new batteries,...
Hi supercrapnst ,
Please follow the below steps..:)
  1. Please make sure that you get your keyboard replaced , in case it's still under warranty , hopefully the supplier would give you a direct replacement.
  2. Check if the keyboard works when connected to your friend's pc , so that you are confirmed that it's not just your pc that is having an issue with the keyboard.
  3. Check if there is any lock key function on the keyboard which locks all the keys together so that you unlock them again with the relevant command , please refer to the manual or the icons on your keyboard , as there are some keyboards which provide this option.
  4. Check the device manger settings, via right clicking on my computer icon --> properties --> hardware --> device manager and see if the keyboard is detected as working properly , if there is an error , you need to reinstall the key board driver and hopefully it will work.
Hope this helps ..:)
May 11, 2011 | Memorex RF 7000 Wireless EZ Touch Keyboard
Computers & Internet Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
