Question about Creda IWD12 Front Load Washer / Dryer
Creda IWD12 makes noise when spinning but still works ok
Machine works fine but the noise when spinning is a problem
  • lukenswm Jan 03, 2009
    Our Creda works fine until the spin cycle but then it sounds like it is off center and the cylinder seems like it is going to disintegrate, the washer bounces and the noise can be heard for about a half a block. There is something seriously wrong with the spinning cycle. Does anybody have a solution here? Otherwise, it works fine.
  • Creda Master
  • 3,463 Answers
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
Posted on Feb 10, 2009
I have a washer-dryer Creda IWD12. How can I reprogram the control PCB C00143471 as it seems to have the program for the washer only model. The drying LED acts as a door lock LED and the heater is con
return the machine from where it came from
its defective and not sold as claimed to be
so.. dont waist your time trying to fix its broken firmware
its defo a duffer...
Feb 08, 2015 | Creda Washing Machines
Creda iwd12 - how to remove the front
Its very simple to do when you fit them daily but first time is very difficult
Nov 03, 2012 | Creda IWD12 Front Load Washer / Dryer
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Programme selector keeps spinning
sounds like the timer is faulty and needs replacing
Oct 19, 2009 | Creda IWD12 Front Load Washer / Dryer
My creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda IWD12 filter.
As far as I remember it goes like this.
take the filter in your hand and turn the knob counter clock wise intill it almost comes off. Then gently shuff it into the filter hole. Push it in as far as you can and than tighten it again.
Maybe the following link will help you
CREDA IWD12
Apr 20, 2008 | Creda IWD12 Front Load Washer / Dryer
Dial keeps turning and clicking
sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Feb 26, 2008 | Creda IWD12 Front Load Washer / Dryer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Creda IWD12 Front Load Washer / Dryer Logo
349 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
