Black streaks down left side of printouts Epson Aculaser C2600
I'm having a bit of bother with one of our printers. When it prints out it has big black vertical streaks right down the left side with smaller streaks on the right side with some slight horizontal marks as well. I have fully cleaned the printer with compressed air and wiped down all that could be wiped down.The streaks actually fade after several prints but then re-appear really bad again when people print after a break. I'm guessing it might be a photoconductor unit problem even though it is only halfway through it's life, but I was wondering if anyone had the same problem and how to rectify it before I fork out on a new photoconductor unit?!
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Posted on Sep 18, 2009
geemarie
  • 876 Answers
SOURCE: Printouts streaked
You have probably made sure that there are no tiny scraps of paper in the machine or no globs of inks in the cartridge slots.
You can go to
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&lang=en&dlc=en&product=439320
and chat with a tech online . Since I don't have your machine in front of me, they will be better able to help you. Good luck to you and thank you for using Fix YA
Posted on Aug 15, 2008
SOURCE: Aculaser C2600 "clean sensor" message
This is a common characteristic which arises from using improperly remanufactured toner cartridges.
Otherwise it is a bad Epson original one - which is highly unusual!
When the C2600 runs through its calibration it prints strips of each colour on the transfer belt which are sensed for density. You will get a "clean sensor message" if the reading for any of the strips drops below a certain value.
The first thing to do is to depress the clean sensor lever behind the front cover several times . If that doesn't fix it I would advise you to remove each cartridge in turn (go to reset menu and scroll down to change toner) and inspect the toner on the surface of the roller. If there is any form of "sheen" then you'll need to replace the cartridge.
It is possible to adjust the doctor blade if you know what you're doing but be careful as there are shims on each side. Loosening and moving the blade bar towards the roller slightly, refixing and then turning the side cog to rotate the roller can sometimes resolve problem. Not a good idea really unless you're in an emergency.
There are some good remanufactured cartridges and bad ones. If you want to avoid this buy genuine Epson cartridges - I know they're expensive but what does the down time cost!
Posted on Jun 19, 2009
DosHog
  • 168 Answers
SOURCE: Toner Streaks Printouts - Lexmark Optra SC 1275
Check the fuser for scratches. BE CAREFUL - - - VERY HOT ! ! !
If you need guidance for this, let me know.
Posted on Aug 12, 2009
SOURCE: Epson Aculaser C2600 Service code E144
This is a Transfer Belt Error - "Worn Out".
This is not a consumable item. Have had to contact Epson direct who have arranged for a service engineer to replace the offending item.
Posted on Nov 13, 2009
cns assoc
  • 677 Answers
SOURCE: printouts have horizontal streaks
Make sure you do the cleaning maitenance,
and must use Original Epson Ink Cartridge.
Good Luck.
Posted on Dec 23, 2009
Is my new Epson printer compatible with Linux
http://www.openprinting.org/printers
http://www.openprinting.org/printers/manufacturer/Epson
Don't really know you failed to provide the exact model number ????????????????????????????????????????????
see if model number is listed in the above link
Jan 09, 2017 | Epson Office Equipment & Supplies
How to download samsung ML-1666 printer driver for windows 7 32 bit
Dear
In windows-7 , the printer automatically down load from samsung website, if the PC detects the printer(try the usb cable conneting from the back panel of the PC). Also you may download from samsung website. Printer Support SAMSUNG India Printer Support SAMSUNG India Printer Support SAMSUNG India
Put your model code on search pocket and click .
Thanks.
Feb 17, 2015 | Samsung Office Equipment & Supplies
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Samsung kicked out hp 3in 1 printer already installed
Don't have your HP designated as the default printer (if possible)when you hook up the Samsung. When the Samsung is hooked up it sees the HP is the default printer. Well it can't have that, they discard the HP drivers. What does Samsung care about HP drivers theres only one printer port setup and thats the USB port you have them sharing. So yes you need to get a second cable. Tim
Jan 29, 2007 | Samsung SPP-2020 Thermal Photo Printer
364 people viewed this question
k24674
