Question about Frigidaire FGF337EC Stainless Steel Gas Kitchen Range
Oven does not heat up
I have an ES300 ceramic cooktop. It is 1 1/2 years old and I bought it at The Bay in Canada. It has been great until yesterday. The oven stopped working. The electronic pad lights up when I touch Bake and the temperature sets and the oven and preheat lights do light up. But there is no heat. The broil works fine. The clock is properly set. On the bottom of the oven [which is very clean] the actual heating coil seems to have a very ragged part near one end. Not burnt on food or anything. It looks like some of it just deteriorated. What would cause this? Could this be the reason the oven doesn't work?
Please help if you can. Warranty is just expired 6 months ago.
S.W.
  • wards410 Dec 02, 2008
    thank you so much for the quick comment. i can't tell you how much i appreciate it.
    where would i find the fuse that may need to be replaced? i have no idea where to look.
    thanks again
    SW
    Problem Solver:
  • 18 Answers
There is a fuse that controls the oven functions.. try replacing it.. good luck!
Posted on Dec 02, 2008
One element not heating. Where do I find a serviceman in Sutherland shire.
There are several that service the area when you Google it - "cooktop service Sutherland Sydney", or you can try
http://www.appliancerepairssutherlandshire.com.au/
Apr 06, 2016 | Cooktops
Maytag electric cooktop popping breaker.
The problem is most likely in the element in one of the coils, if they are the tube type and look like pencil thick heating elements, they can develope a short circuit inside them. The actual heating wire is encased with ceramic filler and then put in that tube. The heating wire moves when it gets hot and can work its way to the case and cause a short. Unhook the power from the whole unit and use the meter to check the rersistance of the coils between the heating element and the case
Jan 13, 2013 | Cooktops
Stains on black cermaic oven top
Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
Mar 06, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
No Heat.
Hi dadedulitl,
When you say "putting out no heat", I take that to mean it's not heating the food up. When a microwave suddenly stops heating food, but still appears to run, it's usually a defective/dead magnetron. Prices for replacement/repair will vary, you will need to find out what that service costs in your locality before having enough information to decide on repair or replacement.
When my first microwave lost it's magnetron (~20 yrs ago), it was 5 years old at the time, and the cost of buying a new oven was only a little more than the repair - but I had the repair done anyhow. Since then, we've replaced the entire oven instead (twice). Newer one's may have more power/less energy wastage, etc.
If it's ~ 3 years old, do you have an extended warranty?
If so, you might be able to use that (check the terms of the EW). Most standard warranties are for 1-2 years max, so unless you bought the EW, you're probably back to deciding between repair and replacement.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 21, 2009 | Panasonic NN-P794SF Microwave Oven
My ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Dec 27, 2008 | GE 30 in. JP340 Electric Cooktop
7 year old white ceramic cooktop stained
I have heard of people using a product called Bar Keepers Friend with great success
Dec 05, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Jan 06, 2008 | Electrolux EOB5600 Ultrafan Electric...
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire FGF337EC Stainless Steel Gas Kitchen Range Logo
491 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
