My computer system after turning on, turned off. cpu fan on and then off. mobo led is green (p4b533 asus). power is good, and unpluged all devices but no change! is cpu dead?
  • Jason Edinger May 11, 2010
    Normally that means that the cpu is overheated. What kind of processor do you have?
  • 61 Answers
Try to remove all the pci card including you display card and chk if it gives any beeps remove memory and chk if it gives you memory beep three long beeps if it does not then remove all the IDE or SATA cables and try to boot i doubt the problem will be with Mobo or power supply
Regards
Samson Ved
Posted on Dec 02, 2008
    Scholar:
  • 160 Answers
Your cpu is probably overheating
turn off the power and unplug the computer and all periferals.
it may be dirty or the cpu fan may be going out. open the case, clean the fan with a can of air and cotton swabs. do not allow the fan blades to rotate freely when blowing them with air by holding them in place (or the bearing may go bad). you may also want to blow out the rest of the case as well and remove each card to clean them with swabs and air.
it will be slow work, but it can save you wear and tear on the entire system by doing so.
put everything back together and try everything to see that they work properly. if the problem persists, you may need to replace the cpu fan or risk damage to the processor.
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computer power ON/OFF behavior is not as expected!
Hi...
If all the parts of your computers are fined functioning. This is a CPU problem witch is no display. Try to disassemble the CPU remove the heat sink the CPU and clean and insert it again. When you are now inserting the CPU be sure that you will put a thermal past in the heat sink so that the heat from the CPU are absorbed. If the heat will not be absorbed it will cause overheating.
Good luck! Thanks for using fixya.
Regards
ICmanServer
Aug 21, 2009 | Computers & Internet
My motherboard Asus P4B533 doesn't turn on not even the Green Led ligth on the motherboard turns on. What could be the problem?
hi, 3 points:has the fuse in the plug gone,or the power supply is blown or lastly the motherboard has blown.Contact chris at 07926-106150 or on http://www.motherboardsrus.net
Jun 08, 2009 | ASUS P4B533-VM Motherboard
Asus A8N-E failing? Chip fan dead?
The CPU fan need to be replaced and the CPU may now be damaged for overheat.
Jan 19, 2009 | ASUS A8N-E Motherboard
Computer won't turn on.
This sounds like an overheat problem, is your cooling fan working properly, also the processor you are using is a powerful one, so needs a cooling fan much more powerful than the lesser powered athlon 64 processors.
Dec 02, 2008 | ASUS CROSSHAIR Motherboard
Intel Media Series Intel G33 chipset micro atx no post no boot after crazy fan
make sure you have seated all the cards properly, take them out and reseat them including the ram. Make sure your IDE cables are plugged in properly as well.
Restart the computer and if still no post then yes unfortunatly for you its the mobo =(
Dec 03, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
D530 CMT minttower power problem
Hi, from your description it appears your power supply is ok.
Remove your RAM chips, clean everything with a soft brush or a can of compressede air [from computer store] Reinstall the RAM making sure it is seated firmly.
If this does not solve the problem, Are you using 1 or 2 RAM sticks? if 2 then remove them again and swap them around.
stick one in dimm2 and stick 2 in dimm 1.
If you only have one stick then beg or borrow another stick and try it. If all fails you may have developed a mobo problem.
Regards mistyman
Oct 13, 2007 | Compaq d530 CMT PC Desktop
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
