Question about Apple iPod MA446LL/A MP3 Player
Ipod saying no music but says there is 20gb left from 80gb
I think i removed the ipod from pc without safely removing it. i had about 60gb of stuff on it and when i turn it on its says no music.i hope i havnt lost all my years of collecting.what should i do to get the music to show up on the ipod and itunes? thanks so much
    Problem Solver:
  • 18 Answers
I never ever had such problem even if u remove widoud disablin (safe remove). try formating ur ipod then copy your stuff and if yet dont work then replace it if it is in warranty
Posted on Dec 02, 2008
CAN YOU PLAY PS2 GAMES ON A PS3?
Only some models were able to play PS2 and PS1 games, these were early 20Gb, 60Gb and some 80Gb models. The 20Gb model number would of been CECHB**, the 60Gb model would of been CECHA** or CECHC** and the 80Gb model would of been CECHE**. Only these models are backwards compatible. The funcionality was removed from newer models and also the new PS3 slim model.
Hope this helps
Oct 30, 2010 | Sony Playstation 3 (PS3) Console
My ipod 80gb is saying apple.com/support/ipod
Try resetting it. Sometimes that's all it needs.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Feb 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
How to play ps2 games on ps3
Ok well here is the "Skinny" 1). 20GB has no chrome trim, no memory card reader and no wi-fi. Not manufactured anymore. Has the best backwards compatibility with PS2 games due to Emotion Engine (PS2's CPU) and Graphics Synthesizer (PS2's GPU) installed.
2). NTSC 60GB has the same backwards compatibility as 20GB version, also has memory card reader and wi-fi. Has a chrome trim.
3). 80GB - extended memory, but reduced backwards compatibility with PS2 games, it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played. Available only in NTSC regions.
4). 40GB - can't play PS2 games at all (all PS2 chips were removed), has 2 USBs instead of 4, no memory card reader, has wi-fi. Avalable in black and white colors. White is on sale only in Japan. Uses 65nm technology (lower power consumption). Improved cooling system. It's the latest version. 40GB doesn't support SACD.
5). PAL 60GB - reduced backwards compatibility with PS2 games. it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played.
Wi-fi included in all models, except 20GB.
Feb 05, 2010 | Sony PlayStation® 3 (80GB) Console
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
I have an ipod 80GB with video out to the TV My 60GB willplay my pictures as a slide show on the TV, but the 80GB will not. Any Suggestions
You probably need different cables for the different ipod. Go to www.apple.com and click on the support tab; after it loads put the article HT1453 into the search. It will pull up the apple article on this exact kind of issue. It has pictures to show the different kinds of cables needed for the TV OUT feature on ipods. I found it very helpful, hope you do as well. Cheers :)
iPod and iPhone: TV out support Last Modified: January 02, 2009 Article: HT1454 Old Article: 300233
Apr 22, 2009 | Apple iPod MA446LL/A MP3 Player
Switching off ipod video 80Gb
The "Do Not Disconnect" message will persist until the the iPod is fully charged. Even after this, the message will still persist - it just does this by default. As long as the spinning wheel in the far upper left-hand corner of your iPod screen no longer appears, the sync has been complete - as soon as it is fully charged, safely remove the hardware on your Windows desktop (or use the Eject button in iTunes - or both), and remove the iPod from your PC.
Mar 23, 2009 | Apple iPod MA446LL/A MP3 Player
I got a Philips HTS3555 and i cant get video to play threw the ipod dock. how do i get it to work?
Verify the you are using compatible equipment
Compatible GoGear/iPod devices for playback via the docking station are as follows:
  • iPods from Generation 4 onwards (80GB, 60GB,30GB, 40GB, 20GB, Mini)
  • iPod Nano (Gen 1 & Gen 2 only)
  • Philips GoGear (SA9200/17 only)
if you are still experiencing problems, let me know
Dec 05, 2008 | Audio Players & Recorders
Apple 20GB IPOD 4th generation corrupted
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Mar 18, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Cannont reset ipod
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
Can not sync with itunes
If you still have all that music on your computer then just update itunes first then update the I-pod. if you don't you are going to have to use an after market program to pull the music from the iPod to your computer first then add it to itunes.
This happens when the original library is lost in itunes or when you install a fresh copy of itunes on your computer.
Dec 27, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Apple iPod MA446LL/A MP3 Player Logo
181 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
