Not sending or receiving faxes
I have a Pitney Bowes PB4512 (plain paper digital copier/fax/printer). It isn't receiving or sending faxes. I have tried an alternative fax in the same phone socket and it works. I have also swapped the cables over, but the fax is still not responding.
When I dial out it makes the appropriate noise and then an undeliverable report shows after several attempts at re-dialing. I have asked somebody to send a fax to me, but they say it is dialling but not coming through.
There doesn't appear to be anything in the trouble shooting section of the manual and I wondered if you had any ideas on the problem
  • sam2812 Dec 03, 2008
    I don't know. The fax has been working fine and then stopped receiving. I know it isn't the plug-in port as I have tried an alternative fax in the port and it works fine. I have also swapped the port cables in case it was that, but it still doesn't work, which suggests that there is a fault with the machine rather than the port.
    I wondered if anybody has an idea of what I should look if it is likely I can make a quick fix to the machine without calling for out of house assistance.
    Genius:
  • 2,120 Answers
Is it a DIGITAL phone line?
Posted on Dec 02, 2008
Pitney Bowes Manual for AD20
I have this manual on my computer. If you send an email to LBrown18062@hotmail.com I will send the manual to you right away. Please put PITNEY 9920 as the subject line. I hope that this will help you out. Lawrence Brown
Oct 21, 2011 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
How to access th menu on a Pitney Bowes 9920 Fax machine?
press function to access menu, any settings that require a pqssword to access it id the model no 9920
Sep 14, 2009 | Pitney Bowes 9920 Plain Paper Fax
Cannot recieve faxes but i can send them
It is set on "manual receive" rather then "automatic receive"....check your "reception mode" settings and set it properly
Jul 16, 2009 | Pitney Bowes 9920 Plain Paper Fax
Always asking for an access code.
You will probably need a technician to set the machine back to it's factory defaults. Sorry
Jun 11, 2009 | Pitney Bowes 9920 Plain Paper Fax
I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Jun 09, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Paper jam on Pitney Bowes 9910
try a new toner, if not it could be fuser
Feb 17, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
jasbo
jasbo
