Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony 60 '' rear projection tv has no red color
I have adjusted the "hue" setting and it does nothing for the red.
Blues and greens seem fine as I can adjust them quite a bit. the picture seems fine, and the clarity and contrast seem ok. I have comcast cable HD input so the signal should be fine. I have call 4 or 5 repair shops and been given estimate ranging from 100 to 1000 dollars. I do not want to be ripped off but understand that it might not be cheap.
Can you please help me solve this problem. Thank You
  • tkung99 Dec 04, 2008
    I have almost the same problem. After a couple of years my Sony Wega 60' screen color picture is not as clear. I mean it's possible read is not working for me. I see green, yellow and blue i think, i also see red at time but again it's not clear so i'm thinking it's possilbe might be one of my light bulb.
  • 3 Answers
First check inputs on hd cable box then on back off tv to see if they are on tight.With you not telling us if this is a rear projection or LCD projection it kind of hard to inform what the promblem is.If rear projection its the RED CRT,if LCD then light engine plumptvdoctor@sbcglobal.net
Posted on Dec 17, 2008
Sony Wega model kv-32fs120. Color is all reds and blues, no greens or yellows. We have tried adjusting the hue as per the owner's manual and also the re-set but nothing changes.
The color of the television are compose of three color RED,GREEN and BLUE.So the lost color is the green.The problem is in the color section of the CRT board in the chroma section and in the CRT socket board.Maybe theres a loose connection in the PCB like the cathode output transistor.
Sep 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 60" HDTV Plasma WEGA....Picture Problem
My guess is that you're not missing the color it just appears muted... That problem is a common one in both the 50 and 60 inch models. And if you change video mode with nothing hooked up you'll see a faint color where none should be...
That's simply dust in the optical block on one of either the red, blue or green lcd panel. Wipe it down with a non-linting cloth and a "light" amount of windex and you're back in business...
But check it out by switchin through the video modes with nothing hooked up.. The faint color you see if the lcd panel that's having the most problem and the one that's muting your green.
Bill
Nov 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Sep 16, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
101 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
