Question about HP Compaq ProLiant DL360 G4 Server
Dl360G4 Accelerator board battery will not hold a charge
I have replaced an accelerator board battery on several HP DL360 G4 Servers several times only to have to replace them 90 days later. Is there something else going on which is not reported in SIM?
  • Rajesh Bhavsar May 11, 2010
    Hi there ,
    Issue not clear specify in more detail
Check your firmware levels and make sure they are current. When you download the latest firmware from itrc.hp.com, take a look at the history/change log in between your version and the current version and see what was fixed. It may shed some light on this problem.
Posted on Jun 08, 2009
How to replace raid card battery
Firstly, shut down the server. Open the top cover and look for the RAID card battery. Should be easy enough to spot it. Unplug it from the board and replace with the new one. Power on your server and look for change notifications.
Sep 30, 2013 | HP ProLiant DL360 G5 Server
Hdd firmware
Hello this should be the servers support homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=397638
First of all an operating system must be installed, to renew the firmware.
But i don`t think that`s the problem in your case.
I have to warn you about upgradeing the firmware.
You must be 100 % sure its the right software or firmware, the controller will die, or be unusefull when loading the wrong firmware !!
The battery holds the write cache in case of power loss.
Acutally the write cache feature will continue to work while the battery is dead. However there will be no opportunity to recover data from the cache should the server fail unexpectedly.
There should be two batteries, one on the controller itself and one on the daughter board (memory). You may have to change both batterys.
A lithium battery should hold the power, for approx 5 years.
Contact a HP support center, to get the new batterys and replace it.
The batterys must be changed, before installing an operating system. You will probably get an error if you try.
Consider also to upgrade the bios itself.
Hope you get it running.
Jun 23, 2013 | HP Computers & Internet
Trying to download norton 3560
You can download a 30 day trial version of Norton 360 version 5 from the link www.norton.com/n360s_5 Once the installation is complete, you can activate the program with the product key if you have one.
Regards,
Muhaim
Apr 22, 2011 | HP Compaq ProLiant DL360 G4 Server
Need Sound Card for HP DL360 G4 with PCI
Try this: First-install the software for the Sound Blaster card. (from the cd if you have it.) Next, if you have Internet access download the latest driver updates for Sound Blaster making sure you get the correct os. (Server is a NOS; Network Operating System) Once all done THEN install the card and reboot your system. This should do the trick.
Good Luck
C2S
May 25, 2010 | HP ProLiant DL360 G4 Server
64 bit os vmware esxi
make sure that the Ubuntu is seeing an X386 and not a X686 emulated processor. Ubuntu stopped support on 686 procs for the 64bit family awhile back. you can choose this under the items.
Apr 20, 2010 | HP Compaq ProLiant DL360 G4 Server
How to booting safe mode in HP DL360 G3 server
As soon as the server turns on and you see a BIOS screen press the F8 key constantly. This should be you to the safe mode screen. If not then try another keyboard, or another USB slot.
Nov 12, 2009 | HP Compaq ProLiant DL360 G4 Server
There are three servers (2 G5s and 1 G4) these servers share a single monitor but i don't use any kvm switch.. I manually switch the connection of the monitor to access the three servers. i use G4 most of...
Do you try disabling Screensaver feature on those two servers...might that be causing display prob, if you try pressing any key or it would show screen
But still if it is not working, Check Power saving feature for these two Server, turn off featue to turn off display and harddisk if computer is standy by for......mins
Hope it resolve issue, Best of Luck
Oct 09, 2009 | HP ProLiant DL360 G5 (457922-001) Server
Hard disk space
Check on the HP website for BIOS updates and Firmware updates for your raid controller. This sounds very odd that there is a 28GB limitation on drive size? What size drives are in there now? They usually step up in size like 9GB, 18GB, 36GB, 72GB, etc.... Your IT guy maybe misinformed.
Oct 16, 2007 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL360 G4 Server Logo
1,158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
