Question about Kenmore 62602 Electric Dryer
Dryer doesnt heat up enough to dry clothes
I checked heating element still have continuity across it and checked thermal fuse on dryer exhaust it still has continuity. there is a round disk with four wires on it could that have something to do with it
  • billsturtele Dec 02, 2008
    thanks i will check that out i did just replace it but maybe the flap is to strong and wont open. thank you
    Sergeant:
    Champion:
  • 291 Answers
Sound like the vent duct going thru the wall to outside is stopped up / check your duct and outside dryer flap to make sure the air is open / if blocked it will take 2-3 times as long to dry and make it seem like the dryer isn't drying / larry
Posted on Dec 02, 2008
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
No heat, clothes are not getting dry
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Sep 06, 2009 | Kenmore 600 7962 Dryer
No heat
Check for a blown thermal fuse or a faulty heating element. Both components are inside the rear of the dryer and can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Very sorry for your trouble and I hope this helped. Best wishes.
Sep 02, 2009 | Maytag MDE7600AY Electric Dryer
Dryer wont put out heat. clothes wont dry.
Check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter. Test for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 15, 2009 | Dryers
Heating element will not work Cloths do not dry. Checked breaker, and electric connection, that is not the problem.
This is caused by a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 13, 2009 | Dryers
My son put soaking wet clothes in dryer....since then clothes wont dry (happened 2-3 weeks ago) took hose off back and ran with it off....still no heat.....help! john
I would check for a blown thermal fuse or faulty heating element. These components can be tested using a multimeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located in the rear of the dryer, usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 04, 2009 | Roper Dryers
Whirlpool dryer takes a long time to dry clothes. On high heat no heat at all
Check for a blown thermal fuse or a faulty heating element. Both components can be checked for continuity using a multimeter. No continuity means the component is defective. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 02, 2009 | Dryers
No heat
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 19, 2008 | Splendide 2000S Vented Washer/Dryer
Dryer does not dry clothes
If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it’s electric, or a burned out igniter if it’s gas.
If one of the two thermal fuses are blown you will not get heat.  Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot.  Often this is caused by not enough air flow through the machine.  Check and make sure your exhaust vent is not clogged.  Clean it the best you can to get all the lint, dead mice, bird nests, etc. out.  Also make sure air is blowing out of the machine when it is turned on.  If not you have a blower problem.
The thermal fuses are located on the element casing.  They each have two wires coming out of them.  They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across.  With a multimeter, check the continuity across the terminals.  If there is no continuity the fuse needs to be replaced.
To check the element(s), you can either visually look and see if it is broken or check the continuity with a multimeter.  No continuity means the element is broken.  Replace if necessary.
To check for a broken igniter, take out the old one and look at it.  If it looks broken or very burned, replace it.
Oct 16, 2007 | Zanussi TC7102W Electric Dryer
Kenmore 62602 Electric Dryer Logo
82 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
