Question about Amana SXD524VW Side by Side Refrigerator
AMANA SRD27S4W ICE MAKER AND WATER DISP. PROBLEM
AFTER FIXING DEEPFREZER FAN AND REPLACING TERMOSTAT ALONG WITH MAIN CIRCUIT PANEL IT SEEMS MADE REFR. WORK. BUT WATER DISP. AND ICEMAKER ARE DEAD.
SolutionGuy
  • 331 Answers
SOURCE: water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Posted on Oct 15, 2007
docjohn174
  • 943 Answers
SOURCE: Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Posted on Sep 18, 2008
aborcass
  • 2651 Answers
SOURCE: Amana fridge SRD27S4W 27CU.IN. 1995 S/S PARTIALLY COOLING
normal to have frost accumlulation, on the evaporator coil, not normal to see it coming thoughthe back panel, which is indictitive of defrost prblem, you can remove the back panel inside freezer compartment and look forthe thermostat( 2 wires leading to a round thermostat clipped onto the top coil of evap, simple to replace simply cut out old and wire in new one heres the part number R0161087
Posted on Dec 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
Posted on May 26, 2009
  • 363 Answers
SOURCE: where is the pump for the ice maker?
The solinoid valve for the water dispenser and ice maker are the same one, it is generally located at the bottom behind the unit.
Posted on Jul 19, 2009
I have whirlpool mod. WRT1L1TZYT00. Refr. It is
Normally, drain tube runs along the back outside wall of a top mounted refrigerator. Follow that tube all the way to the drain pan and see if it is line up with the drain pan. If it is, look for a crack in the drain tube.
Oct 01, 2014 | Refrigerators
NO ICE IN FREEZER--ARM IS DOWN AND WATER SUPPLY IS ON.
Can be any of the following faulty ice maker, faulty water fill valve(it has 2 valve one for the front disp and one for the ice maker) or a frozen water line from or to the filter assembly.
Apr 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker Water leaks out of tray after filled. Is side mount Ice maker hard wired or plug in 1996 26' side by side Amana
All icemakers are plug in . 2 screws hold the main mount and mayby 1 below . Replacing icemaker , is the correct thing to do . The coating gives way after so many years , holding water in the bubbles , and since the same amount goes in each fill cycle , the water under the coating always takes up space therfore , icemaker overflows .
Sep 02, 2009 | Refrigerators
My refr. comp. is runs but the evap.fan motor do not run
Look inside the freezer at the back panel. Is it covered with ice? If it is you most likely have a bad defrost heater and the ice has stopped you fan. If not you will need to replace the fan
Please rate this solution if it is correct. Thanks.
Aug 19, 2009 | Amana ASD2625KE Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Nov 27, 2008 | Amana SXD524VW Side by Side Refrigerator
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Amana SXD524VW Side by Side Refrigerator Logo
98 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
