Question about Microsoft Office Professional 2007 Full Version for PC
Problems with receiving e-mails with office 2007
There is a problem my office outlook 2007 when start up e-mails are receiving but then become very slow takes 15 to 30 minutes to recieve e-mails at start up i check for virus???? any suggestions??
  • 51 Answers
The first thing to try to fix this problem is to run office diagnostics.
It can be found in Help->Office Diagnostics.
If this doesn't fix the problem.You can try this link for more solutions.
Thank you.
http://www.roundtripsolutions.com/blog/2007/02/19/208/problem-with-outlook-2007-email-receive-is-broken/
Posted on Dec 02, 2008
When opening Outlook I receive the following message, this occurred after I tried to email a photo out of a photo program: "A data file did not close properly the last time it was used and is being...
1. In Outlook 2007, click the Tools menu and select Options.
2. In the Options dialog box, click the Mail Setup tab and then click the Data Files button.
3. In the Account settings window, you will see all of your personal Outlook data files listed. Here, you want to note the full path to each data file. On my system, my Outlook personal and archive folders are stored in the C:\Documents and Settings\Your Username\Local Settings\Application Data\Microsoft\Outlook folder.
4. Once you have this information, close the Account Settings dialog box and then close the Outlook Options window.
Now that you have the location of your Outlook data files, you need to check and repair them using the Microsoft Office Outlook 2007 Inbox Repair Tool-SCANPST.exe. By default, you should see SCANPST.exe in the Microsoft Office installation folder's "Office 12" subfolder. On my system, SCANPST.exe is located in C:\Program Files\Microsoft Office\Office 12. For additional information on SCANPST.exe, take a look at the Microsoft Knowledge Base article, "How to use the Inbox Repair Tools to recover e-mail messages in Outlook 2002 and Outlook 2003."
To check and repair your Outlook data files, follow these steps:
1. First, close Outlook 2007.
2. Use Windows Explorer to browse to SCANPST.exe, then double-click it.
3. When the Outlook 2007 Inbox Repair Tool opens, click Browse and navigate to the Outlook data file location that you found earlier. Note that you will need to check each file listed. On my system, I start with the file archive.pst. To check that file, you would select it in the "Select File to Scan" dialog box and then click Open.
4. Now click Start to begin the repair process.
Mar 05, 2011 | Sony Microsoft Office Standard 2007
Tip
How to disable "Perform an automatic send/receive when exiting" in Outlook 2007...
If you are having trouble with Outlook closing it is possible that there is a problem with Outlook its self. However one of the things that I have found is that the "Perform an automatic send/receive when exiting" option is turned on. Below is the steps to check to see if this in enabled in Outlook 2007.
1. Click on Tools then Options in the menu bar.
2. Once in Option click on the Mail Setup tab
3. Click on the Send/Receive button.
4. Make sure "Perform an automatic send/receive when exiting" is unchecked
5. Click Close
6. Click OK
Note normally in a corporate environment this is not turned. If "Perform an automatic send/receive when exiting" was already disabled and you are still having trouble with Outlook closing you may need to reinstall Office on the computer.
on Apr 17, 2010 | Microsoft Office Outlook 2007 for PC
It is not a problem but a question. Can I install Outlook in windows 7 and will ntelos support it as my mailbox?
Yes, but you will need to make sure if the version of Outlook that you have is comaptible to windows 7.
Officially only Outlook 2003 and Outlook 2007 are supported to run on Windows 7. This is similar to Windows Vista which also did not support earlier versions of Outlook. You can install a version prior to Outlook 2003 on Windows 7 though but there are several issues which you could encounter.
In addition to these version requirements, even with Outlook 2003 and Outlook 2007 there are several compatibility issues which you could encounter on Windows 7. The most critical of these issues have been taken care off in prior service pack releases. So before starting Outlook on Windows 7, make sure your first apply at least Service Pack 3 for Office 2003 and Service Pack 2 for Office 2007.
Hope this will help...Your response is very much appreciated...
Jan 24, 2011 | Computers & Internet
Cannot send/recieve mail outlook express
If you have installed Microsoft Office Outlook 2007, it will set itself as your default mail client. Hit the Windows ball or Start button on the lower left of the desktop - All Programs - Outlook Express. When it opens; hit File - Export - To Outlook (Messages). Outlook Express will export all of your messages, contacts and account settings to Outlook 2007 and you will be able to use the better, upgraded Outlook Mail client.
Oct 13, 2010 | Microsoft Office Outlook 2007: Windows
Outlook will not activate
It is because MS outlook is not a part of the ms office home and student 2007 package. That's the reason why your outlook is saying trial and its not working.
Mar 20, 2010 | Microsoft Office Outlook 2007: Windows
Cannot open microsoft office outlook for my e-mail.
Your Outlook could have received a corrupted email that override your inbox folder. Try doing a System Restore.
Mar 17, 2010 | Microsoft Office Outlook 2003 for PC
Outlook 2007 Windows Vista will not allow hyperinks
You might find the answer to your question here:
http://office.microsoft.com/en-us/outlook/HA012299621033.aspx
In short:
Stop disabling links and functionality in all messages
1. On the Tools menu, click Options.
2. On the Preferences tab, under E-mail, click Junk E-mail.
3. Clear the Disable links and other functionality in phishing messages (recommended) check box.
Note If you decide to select this check box later, Outlook will disable all the links in messages that were evaluated as suspicious by the Junk E-mail Filter, and you will receive warnings about suspicious links.
Also read the complete topic. There is some interesting stuff inside..
Jun 01, 2009 | Microsoft Office Outlook 2007: Windows
Outgoing message does not go with Outlook 2007
It sounds like your SMTP settings are incorrect, if you are using a POP3 service, it can connect and download your email, but most ISP Mail SMTP servers dont allow outgoing mail from another ISP.
Example, I have a charter.net email account but I have wireless hometown as my ISP, so I have to set my POP3 settings to my charter.net account (incoming messages) and my SMTP settings to wireless hometown smtp server for (outgoing mail)
Mar 10, 2009 | Microsoft Office Outlook 2007: Windows
Outlook 2007 problem
In microsoft Office tools Programs menu, Click on Microsoft Office Diagnostics
SM
Apr 04, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
