Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-61HS30 green problem....
Hello, When first turning on the set, there is too much green color. Black and white pictures will have a green tint. After the set is on for about a half hour, the overwhelming green subsides. Is there a known fix for this and is that fix expensive? Thank you....!!!!
  • cohagen Dec 12, 2008
    I have the sae problem except mine is blue.
  • dee jay Dec 31, 2008
    I have the same problem. My sony projection TV model KP-61HS30 started showing a green tinted picture when I added a DVD Player to it. I am not sure if adding a DVD player has anything to do with it. After the picture turned tinted green, I tried disconnecting the DVD player but it still shows the green tint.
  • 505 Answers
Unfortinately its likely a bad green CRT. If it stablizes over time, then no adjustment will help you. CRTs are expensive so its best to turn it on 30 minutes before you need it.
Posted on Dec 07, 2008
KP-61HS30 is too green
JUST GO IN TO SETINGS AND TEREN THE COLOR DOUWN OR TREY THE BRITNES
Apr 08, 2014 | Sony KP-61HS30 TV
Look like the image is divide on three.red,blue,green .yesterday was normal.my son finish video game and turn off.Today I turn on and the image cannot show all colors together.
this is a normal problum pls. check remot cantrol on menu key press then selact convergen seting see on the screen canter three cross line arrow to set UP / DW/ LIFT/ RIGHT key maeching 3 line and see cross line is White then see the pictuer is ok
if not working convergen seting then spare STK replace in inside your tv set
Oct 29, 2009 | Sony KP-61HS30 TV
Green tint to sony kds-a2020
NOT ON THIS SET YOUR LIGHT ENGINE IS DEFECTIVE CALL sONY AND SEE IF IT IS ON THE EXTENDED WARRANTY LIST.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Sony KP-57WS500 57" Rear Projection Television Logo
70 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
