Question about Labtec Logitech 1200 Webcam
I'm trying to install a webcam but i keep on getting an error message saying: can't open vfw ! twainui has to exit. What does that mean? any suggestions> thanks, paula
  • 3 more comments
  • paula_reger Dec 02, 2008
    it is a micro innovation ic435c
    I already tried that. any other suggestions? :)
    thanks,
    p
  • paula_reger Dec 04, 2008
    the exact error message is: can't open vfw ! TwainUI has to exit.
    I think the main problem is that I have a bootleg copy of windows xp which is missing some files, but I have gotten around that problem in the past when installing other stuff, i know it can be done, just gotta mess around with it a little.
    What is 'vfw'?
    And what is 'twainUI'?
    when I checked out the device manager there is nothing that is conflicting there so I dont know???
    paula
  • Jason Edinger May 11, 2010
    What is the model of the webcam?
  • 124 Answers
Download the software here and let me know if that helps:
http://www.toggle.com/lv/software/download/kl50433.htm
Posted on Dec 02, 2008
  • Jason Edinger Dec 02, 2008
    can you post the exact error message?
  • 51 Answers
The installation may be corrupted, Try downloading the software and install it.
If the webcam is logitech you can download from the below link.
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=in,en
Please select the product and download.
Says I dont have the vfw driver
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 11, 2012 | GE MiniCam Pro HO98756 Webcam
Frozen video on calls
Try putting the camera under VFW (Video For Windows) control - it involves a registry edit and can be found here
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamfix.html
It didnt work for me at first - I had to download the windows amcap as well. VFW doubled my fps
If you open the 'webcam' menu on the webcam picture frame and also open 'Statistics' you can monitor the f/p/s during transmission - Generally try and keep the frames per second above 1.0 fps to prevent freezing. I transmit the 'small image' with my contacts and they zoom up to 200% -all on the webcam frame menu. When you open 'Statistics' you can tell if you are on VFW control - it will say VFW along the lower panel.
I also increased my virtual memory following an error message.
Sep 28, 2009 | Logitech QuickCam Connect Webcam
I keep getting the message "Initialization Error".
Do you have DirectX installed on your computer ?
For mor information read :-
http://support.microsoft.com/kb/933311
Aug 15, 2009 | Microsoft LifeCam VX-1000 Webcam
Problem on cam
I used to get this when I was on dial-up but never since going broadband - so the bandwidth may be fragile.
You need to interrogate what is happening when the webcam is transmitting by opening the webcam menu on the webcam frame and click "statistics" Its best to transmit the "small" image and use the zoom 200% when established ( same as sending large photos by email ) - if I go for speed rather than quality on the slider I can achieve 5-6 frames per second ( small size) but I normally transmit about 1-2 f/s.
I have my webcam under VFW (video for windows) control as I used to get freeze problems. This involves a registry change - detailed in Messenger help
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamfix.html
You can tell when its under VFW control because VFW will be on the bottom of the Statistics box. You may need a little bit of software to make it work, if like me you do not have Directx on your pc - if so download the software featured here.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstatestcamie.html
Dont worry about using the proxy server in "Connections" - Use it when you have to - I had to use it today to make my my webcam work - I also had to increase my virtual memory but that was as a result of error messages
Aug 12, 2009 | Labtec 961307-0914 Webcam
Error Notice ::: Error at CVFWimpt: Open () Can't open VFW TWAINUI has to exit I was installing a HP Webcam and same erroe comes up have gone to HP website got new driver and down loaded it and same...
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Aug 13, 2008 | Computers & Internet
Hi!
The pro and plus models are the same thing. You have to install the software before plugging teh camera in ortherwise windows assigns an incorrect driver.
Jul 23, 2008 | GE EasyCam Plus Webcam
Labtec Logitech 1200 Webcam Logo
198 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
