Question about Compaq Presario R3000 Notebook
My laptop makes a sound while starting after shutting down
But no noise on starting after hibernating or during restarting.Also on opening word/excel files the curser is simply moving on so without any touch in space bar/enter keys making it difficult the editing job. when trying to shut down ,the various options such as hibernate,restart etc., are simply scrolling down making it difficult to select a particular action. The touchpad is working just to move cursor from place to place ,let to right,top to bottom etc.,but no action when cursor is brought to a folder and applied smooth touch to open it.To open or close a window, i have to bring the cursor point to closing tool"X" and then click left button of touchpad.This problem started from 0840am on 1-12-08 pl help me immediately
  • Alex Smallwood
    Alex Smallwood May 11, 2010
    Whats the sound?
    If it beeps , count the number of beeps and check your documentation as computer beep codes correspond to a problem with a certain piece of hardware , depending on the number of beeps
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Toshiba A215-S4767 will not start up correctly.
First off, Windows just didn't like the way the computer shut off, I would just restart normally and see what happens. Next when it boots up and you get into windows, Go to the control panel > Power Options > go to the hibernation tab and make sure hibernation is unchecked. Next go the setting that reads "shutting the lid". You want to open this setting with a drop down list and pick "Do Nothing", this will keep the laptop from entering standby mode just for shutting the lid. Laptops do not like hibernation or standby modes....windows hates it and will give you all kinds of problems if you continue to use it.
Sep 27, 2009 | Toshiba Satellite A215-S4767 Notebook
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
Motherboard voltage solution for hibenation?
Press the FN key and the F5 key at the same time. You MIGHT have it in other monitor mode.
Feb 06, 2009 | Toshiba Satellite 1415-S173 Notebook
Shutting down ,HIbernating
open control panel then display then click screen saver
then power at bottom of page In there you will find Hibernate and other settings that you can change you can disable able hibernate standby and sleep
Then click apply
restart let me know if this was helpful
Jan 19, 2009 | HP Pavilion dv9000z Notebook
Hibernation
This doesn't sound like a hibernation problem, it sounds to be much deep, motherboard deeper, but let's rule out the hibernation. Unplug the laptop, take out the battery, this will completely shut the machine down. Then put every thing back and restart. If it starts, then disable the hibernation mode in the display properties, screen saver tab, under the button that reads power. If it doesn't start, then the problem is with the motherboard or one of it's components. Take it in for a professional diagnostic, they will be able to tell you exactly where the problem is and if it's a replaceable component.
Jul 23, 2008 | Toshiba Satellite M105-S3004 Notebook
Hp Laptop problem
conect a external monitor to see if there is any image or if it is the same maybe the memory or prosesor damage
Dec 30, 2007 | Computers & Internet
Compaq Presario R3000 Notebook Logo
358 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
