Question about Whirlpool AWM029 Front Load Washer
Whirlpool AWM049 washing machine door will not open
Door will not one after washing cycle ends.
SOURCE:
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
chad7houston
  • 62 Answers
SOURCE: Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Posted on Nov 01, 2008
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    • 4 Answers
    SOURCE: Whirlpool AWM8121 ?door open? light flashing
    I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
    Posted on Dec 13, 2008
    • 262 Answers
    SOURCE: Front door gasket whirlpool duet washer
    before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
    bill
    Posted on Jan 08, 2009
    How do I unlock a whirlpool duet washer
    from a previous discussion:
    Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
    Jan 04, 2015 | Whirlpool Washing Machines
    Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Whirlpool frontload washing machine door will not open after the
    if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
    then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
    Jun 21, 2010 | Washing Machines
    Duet GHW9150P Front Load Washer: I put my machine on pause and now I can't restart....
    Press "end of cycle" for 3 seconds, wait for 2 minutes, try door. Shut door and restart your cycle. If door still does not open - repeat 'end of cycle' press for another 3 seconds.
    May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine is not working
    Sounds like faulty door interlock switch / door should not be able to open during programme .....
    Mar 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Front loader AWM 6100 - door open light flashes and won't wash
    I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
    Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
    Dead in the water
    End of cycle? After the end of cycle you have to wait for 2 minutes minimum (or hear a click), only then you have to try the door; or your door won't open & if you force it you'll damage the door mechanism (not good). End of cycle means "your wash is done".
    Pl rate if helped.
    May 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine door blocked
    Try to unplug the unit for 10 to 15 minunets, the washer may reset its self to default mode.
    Feb 13, 2008 | Whirlpool AWM6120 Front Load Washer
    Door on washer will not open
    Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
    Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool AWM5125 - door won't open
    i unplugged mine from the wall and that worked
    Nov 29, 2006 | Whirlpool AWM5125/1 Front Load Washer
    Whirlpool AWM029 Front Load Washer Logo
    106 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
