Question about ASUS W5F - S Notebook
Cannot use dial up
Sorry for my english. I tried to surf in the internet by using these methods: 1. wireless 2. utp network 3. dial up with Toshiba satellite A10, these three method are running. But not with Asus W5F. Only no. 1 & 2 are running well, not with dial up. Any solution? FYI, I re-installed the system with licensed Windows XP pro. Regards, Yanto
    Sergeant:
  • 310 Answers
I know its stupid but are you sure the correct drivers are installed for the dial up modem? check by control panel, system, device manager and look for any yellow or red tags next to anything John
Posted on Feb 26, 2007
SOURCE:
I have an Acer Aspire 5552. It is unable to find any networks. wen I troubleshoot the problem, it tells me te wireless capability is turned off. I have tried Fn F3. it is still giving me the same error....
hi there.
Try this 1
1) Click on start --> In search bar, type ncpa.cpl and press Enter.
"Network Connections" will be opened.
2) Right-click on your "Wireless Network Adapter" --> Properties -->
Select "Internet Protocol Version(TCP/IPv4) --> Click on "Properties"
button --> Make sure "Obtain an IP address automatically" is selected
--> Click on OK --> OK.
3) If the problem still exists then check your SSID and the wireless password.
Function F3 no longer turns on the wireless on my Acer Aspire 5253 laptop.
Do you receive any message or code while turning on wifi?
There is a tiny switch on the side of the laptop (on in the front) that turns the wireless ON/OFF. Make sure you've switched it on.
Method 1: Run the network troubleshooter and check if it fixes the issue:
http://windows.microsoft.com/en-US/windows7/Using-the-Network-troubleshooter-in-Windows-7
Method 2: Do the following to change the wifi settings:
a.Click Start, type network and sharing center in the Start search box and hit Enter.
b.Click Change adapter settings.
c.Right-click the connection and select Enable.
To know more about how to "Set up a wireless network".
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network.
if none off the above works try this link out as well.
Acer Aspire 5552 wireless capability is turned off Google Search
Nov 20, 2017 | Computers & Internet
Tip
How to connect a playstaion 3 to the internet
here are 2 ways to connect your PlayStation 3 to the Internet; using a wired (Ethernet) connection or through a wireless connection. <img src="ps3_connection.jpg" /> <br /> <span>1. Wired Connection</span> 1. Make sure that your PlayStation 3 is connected to a broadband-enabled network using an Ethernet cable.<br /> <br /> <img src="full_setting.jpg" /> 2. Click <b> Settings </b> in the Home menu, then <b>Network Settings</b>. <br /> <br /> <br /> 3. Click <b>Internet Connection Settings </b><img src="network_icon.jpg" />. Then press the <img src="cross.jpg" /> button. <br />4. A message will pop up saying that you will be disconnected from the Internet. Choose <b>Yes</b>. Then press the <img src="cross.jpg" /> button. <br /> <br /> <img src="ps31.jpg" /> 5. When you are given the choice of connection methods choose <b>Wired Connection</b>.<br /> <img src="ps35.jpg" /> 6. Choose <b>Easy</b> - the basic settings are automatically set. <br /> 7. Now click <b>Save</b>. <br /> 8. If you want to you can now test your wired connection by clicking <b>Test Connection</b>. Your PlayStation 3 will now try and connect to the Internet. If the connection isn't successful you should follow the instructions which will appear, to check your settings. <br /> <span>2. Wireless Connection</span> 1. Click <b> Settings </b>in the Home menu, then Network Settings. <br /> <img src="full_setting.jpg" /> 2. Click <b>Internet Connection Settings </b><img src="network_icon.jpg" />. Then press the <img src="cross.jpg" /> button. <br /> 3. A message will pop up saying that you will be disconnected from the Internet. Choose <b>Yes</b>. Then press the <img src="cross.jpg" /> button. <br /> <br /> <img src="ps31.jpg" /> 4. When you are given the choice of connection methods choose <b>Wireless Connection</b>. <br /> <img src="ps32.jpg" /> 5. Now choose <b>Scan</b>. Your PlayStation 3 will now search for any available access points and show these in a list. <br /> Note: Some PlayStation 3 models have an 'Automatic' option, which if followed will complete the required settings for you automatically. Simply click on <b>Automatic</b> if the access point you are using supports automatic setup. <br /> <img src="ps33.jpg" /> 6. From the list of access points choose one which you'd like to use. <br /> <img src="ps31.jpg" /> 7. Check the SSID for the access point, press the right button. If you don't know what the SSID is then you should contact the person who setup or runs the access point for more information. <br /> 8. Select the security method necessary, press the right button. <br /> <img src="ps34.jpg" /> <br /> <br /> 9. Enter the encryption key. This will be shown as a series of asterisks (*). If you don't know what the encryption key is you should contact the person who setup or runs the access point for more information. <br /> 10. Now press the <b>right</b> button. <br /> <img src="ps35.jpg" /> <br /> 11. Choose either <b>Easy</b> or <b>Custom </b>and adjust the settings. <br /> <ul> <ul> <li> <b>Easy</b> - the basic settings are automatically set. </li> <li> <b>Custom</b> - you will need to enter the settings manually. </li></ul></ul> 12. Now click <b>Save</b>. <br /> 13. If you want to you can now test your wireless connection by clicking <b>Test Connection</b>. If the connection isn't successful you should follow the instructions which will appear, to check your settings. <br />
on Mar 22, 2011 | Video Game Consoles & Games
My laptop wont connect to my wireless router, it just says acquiring network address all the time, it does connect to other wireless routers though?
To connect a laptop to a wireless network for accessing internet....you have two ways:-
1. DHCP (Dynamic Host Control Protocol) 2. Manual entry of settings in wireless adapter properties.
1.DHCP:- In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network router settings.
2. Manual entry of settings in wireless adapter properties. This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
* IP address (Its format is "xxx.xxx.xxx.xxx") * Default gateway address (very important) * Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast) * Subnet Mask (not needed mostly...automatically generated)
To enter these settings you have to rightclick the Wireless Adapter>> and select properties>>Then double click the Internet Protocol version 4(TCP/IPv4) and enter these settings. In many cases when you are using proxy server then you have yo use proxy settings also in your browser..
Hope this will help 4 sure....Cheers..:)
Sep 30, 2010 | Acer Aspire 3610 Notebook
Hi i try to connect to my wireless but none of the network places come up it say's 'turn on wireless capability' theres two button underneath the laptop i tried but it doesent work PLZZ HELP!!
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
Hope this will help..........Cheers:)
Sep 25, 2010 | Acer Computers & Internet
My 8330 does not let me browse the internet on my
Hi BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
To set up a tethered modem, complete the following tasks from A to D
A) Install BlackBerry Desktop Software 4.1 or later on your computer.
B) To set up an Internet APN, complete the following steps:
1) Click Start > Settings > Control Panel.
2) Double-click Phone and Modem Options.
3) In the Phone and Modem Options window, click the Modems tab.
4) Select Standard Modem and click Properties.
5) Click Change Settings.
6) In the Standard Modem Properties window, click the Advanced tab.
7) In the Extra initialization commands field, type the following:
+cgdcont=1,"IP","<your Internet APN>"
The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
8) Click OK.
9) In the Phone and Modem Options window, click OK.
C) To configure dial-up networking, complete the procedure that is appropriate for Windows Vista
1) Click Start.
2) Select Connect To.
3) Click Setup a connection or network.
4) Click Setup a dialup connection.
5) In the Dial-up phone number field type *99#.
6) Type the user name and password provided by your wireless service provider.
7) In the Connection Name field type BlackBerry.
8) Click Dialing Rules.
9) Make sure the profile created in Task 2 has been selected, and then click OK.
10) Select Connect to establish an Internet.
D) To connect to the Internet using dial-up networking, complete the following steps:
During this procedure, do not operate the BlackBerry Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Start > Settings > Network Connections > <name of your new connection>.
4) Type the user name and password provided by your wireless service provider.
5) Click Dial.I hope this information will help you
Nov 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Connect a router
Are you trying to set up the router ?
Or you are trying to connect to the wireless network.
It is very easy to set up the router.
I hope the following link will help you
Click Here for step by step solutions
Nov 06, 2009 | Linksys Wireless-G Broadband Router
Iam not able to connect to internet via wireless router
Need more information to help you.
1. If not using the router at all is there connection to the internet??
2. When working woth a utp cable between computer an router is there internet connection??
Don't forgett getting connection with your wireless network is not the same as gettin connected with the internet.
Suggestion: Clone your computer MAC address in the router.
Jan 23, 2008 | Linksys Wireless-G Broadband Router
Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Jan 11, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
ASUS W5F - S Notebook Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
