Question about Asko W660
Asko w660 - will not run due to "overflow" error...can i fix this
There appears to be no suggestions in the manual for this error other than call a technician. Is this something that could be potentially solved without calling in a technician?
4 Suggested Answers
  • 351 Answers
SOURCE: Asko W6441 Washer
tip machine back to see if water runs out,then see if it runs.but you may have a leak.also remove top panel and see if grey vent hose on rear of soap draw is leaking on drum end if so replace and glue.if water leaks from there it will damage the motor bearings ant the thermistor that sits above the motor.just tie the door release back on.look into the pump with a tourch,you may fin somthing still in there because if it cant drain it will over fill and cause on overflow fault.hope this helps
Posted on Mar 23, 2008
  • 333 Answers
SOURCE: ASKO w660 Parts
lick on this link and contact the parts warehouse they will be able to help you. http://www.askousa.com/buy-asko/contact-us/
Posted on Jan 16, 2009
SOURCE: Trying to find asoap despenser
Go to repairclinic.com
Posted on Mar 07, 2009
Asko washing machine w660 "Temperature stop failure"
DOES THIS MODEL WASHER ACTUALLY HEAT THE WATER? OR JUST ALLOWS A CERTAIN AMOUNT OF HOT WATER TO BE RELEASED OR MIXED WITH COLD WATER? U CAN CHECK THE SWITCH WITH A MULTI METER FOR OHMS OR CONTINUITY NO NEED FOR A TECH GUY
Jan 10, 2014 | Asko Washing Machines
Controls don't work after ASKO W660 "fault indication overflow"
Check that water has not got into the very bottom of the machine. Many machines have a drip tray that will shut the machine down if water is present to reduce the risk of f
Nov 09, 2013 | Asko 24 in. D3120 Dishwasher
Washer 660, water dose no stop, and runs out of the machine?
Try pressing P1 five times and then press the door button (with the key symbol). This resets the rinse sensor. If it overfills again, you probably have a bad cpu.
Apr 05, 2009 | Asko W660
ASKO w660 Parts
Jan 16, 2009 | Asko W660
Asko W6441 Washer
Mar 21, 2008 | Asko W6441 Front Load Washer
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
